メインコンテンツにスキップ
KitchenAid KSB5CR Motor Replacement
必要な工具と部品
  1. KitchenAid KSB5CR Motor Replacement, Removing the Back Panel Part 1: 手順 1、 3の画像 1 KitchenAid KSB5CR Motor Replacement, Removing the Back Panel Part 1: 手順 1、 3の画像 2 KitchenAid KSB5CR Motor Replacement, Removing the Back Panel Part 1: 手順 1、 3の画像 3
    • Remove the glass container and place the blender upside down on a solid surface.
    • Remove the four rubber feet using the needle nose pliers.
    • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
  2. KitchenAid KSB5CR Motor Replacement, Removing the Back Panel Part 2: 手順 2、 1の画像 1
    • Lift the back panel up, sliding it along the power cord.
  3. KitchenAid KSB5CR Motor Replacement, Removing the Fan Chassis Part 1: 手順 3、 3の画像 1 KitchenAid KSB5CR Motor Replacement, Removing the Fan Chassis Part 1: 手順 3、 3の画像 2 KitchenAid KSB5CR Motor Replacement, Removing the Fan Chassis Part 1: 手順 3、 3の画像 3
    • Remove the two #5 Phillips 95 mm machine screws using the Phillips #2 screwdriver.
    • Remove the rubber O-ring by lifting it up.
    • Remove the ribbon cable from the chassis by lifting it up.
  4. KitchenAid KSB5CR Motor Replacement, Removing the Fan Chassis Part 2: 手順 4、 3の画像 1 KitchenAid KSB5CR Motor Replacement, Removing the Fan Chassis Part 2: 手順 4、 3の画像 2 KitchenAid KSB5CR Motor Replacement, Removing the Fan Chassis Part 2: 手順 4、 3の画像 3
    • Unhook the white wire that is looped around the peg by pulling it out of the clip.
    • Repeat this process with the red wire on the other side of the chassis.
    • Remove the end cap using the 8" needle nose pliers.
    • Pull up the fan chassis.
  5. KitchenAid KSB5CR Motor Replacement, Removing the Fan: 手順 5、 1の画像 1
    • Remove the fan by lifting it upwards.
    • This step is difficult and requires force. Use of both hands is recommended.
  6. KitchenAid KSB5CR Motor Replacement, Removing the Metal Cap: 手順 6、 1の画像 1
    • Use the needle nose pliers to turn the coupling clockwise to loosen it.
  7. KitchenAid KSB5CR Motor Replacement, Removing the Screws: 手順 7、 1の画像 1
    • Rotate the blender 90 degrees clockwise.
    • Remove the two #8 Phillips 12 mm screws using the Phillips #2 screwdriver.
  8. KitchenAid KSB5CR Motor Replacement, Detatching the Wire: 手順 8、 1の画像 1
    • Slide the knife in the metal loop holding the insulation before the white copper wire, and wiggle the knife back and forth until it loosens.
    • Pull the wire out from the metal loop that you loosened.
  9. KitchenAid KSB5CR Motor Replacement, Removing the Motor: 手順 9、 1の画像 1
    • Lift the motor up out of the chassis.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Cameron Geehr
メンバー登録日: 09/28/14
745 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 12-5, Forte Fall 2014 Cal Poly, Team 12-5, Forte Fall 2014人のメンバー
CPSU-FORTE-F14S12G5
5 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 14
過去 30 日: 41
今までの合計 4,016
