メインコンテンツにスキップ
KitchenAid KSB5CR Fan Replacement
必要な工具と部品
  1. KitchenAid KSB5CR Fan Replacement, Removing the Back Panel Part 1: 手順 1、 3の画像 1 KitchenAid KSB5CR Fan Replacement, Removing the Back Panel Part 1: 手順 1、 3の画像 2 KitchenAid KSB5CR Fan Replacement, Removing the Back Panel Part 1: 手順 1、 3の画像 3
    • Remove the glass container and place the blender upside down on a solid surface.
    • Remove the four rubber feet using the needle nose pliers.
    • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
  2. KitchenAid KSB5CR Fan Replacement, Removing the Back Panel Part 2: 手順 2、 1の画像 1
    • Lift the back panel up, sliding it along the power cord.
  3. KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 1: 手順 3、 3の画像 1 KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 1: 手順 3、 3の画像 2 KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 1: 手順 3、 3の画像 3
    • Remove the two #5 Phillips 95 mm machine screws using the Phillips #2 screwdriver.
    • Remove the rubber O-ring by lifting it up.
    • Remove the ribbon cable from the chassis by lifting it up.
  4. KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 2: 手順 4、 3の画像 1 KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 2: 手順 4、 3の画像 2 KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 2: 手順 4、 3の画像 3
    • Unhook the white wire that is looped around the peg by pulling it out of the clip.
    • Repeat this process with the red wire on the other side of the chassis.
    • Remove the end cap using the 8" needle nose pliers.
    • Pull up the fan chassis.
  5. KitchenAid KSB5CR Fan Replacement, Removing the Fan: 手順 5、 1の画像 1
    • Remove the fan by lifting it upwards.
    • This step is difficult and requires force. Use of both hands is recommended.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Cameron Geehr
メンバー登録日: 09/28/14
745 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 12-5, Forte Fall 2014 Cal Poly, Team 12-5, Forte Fall 2014人のメンバー
CPSU-FORTE-F14S12G5
5 メンバー
6のガイドは作成済み
3 件のコメント
Hi,
Do you know if it is possible to convert Kitchenaid Artisan stand mixer to 240v, has anyone looked inside or know if i should change something.
Ancient warrior - 返信
Does raplacing the fan mean that the fan itself (when broken) can be ordered? So just the white plastic round part. If so, could someone please give me a reference number? Would be highly appreciated.
Hugo, the Netherlands.
Hugo - 返信
my blender turn on all the numbers light at the same time and is not working at all. do you know what the problem could be?
patricia - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 15
今までの合計 2,213
