メインコンテンツにスキップ
KitchenAid KSB5CR Circuit Board Replacement
必要な工具と部品
  1. KitchenAid KSB5CR Circuit Board Replacement, Removing the Back Panel Part 1: 手順 1、 3の画像 1 KitchenAid KSB5CR Circuit Board Replacement, Removing the Back Panel Part 1: 手順 1、 3の画像 2 KitchenAid KSB5CR Circuit Board Replacement, Removing the Back Panel Part 1: 手順 1、 3の画像 3
    • Remove the glass container and place the blender upside down on a solid surface.
    • Remove the four rubber feet using the needle nose pliers.
    • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
  2. KitchenAid KSB5CR Circuit Board Replacement, Removing the Back Panel Part 2: 手順 2、 1の画像 1
    • Lift the back panel up, sliding it along the power cord.
  3. KitchenAid KSB5CR Circuit Board Replacement, Removing the O-Ring: 手順 3、 2の画像 1 KitchenAid KSB5CR Circuit Board Replacement, Removing the O-Ring: 手順 3、 2の画像 2
    • Remove the two #6 Hex 82mm screws using the Phillips #2 screwdriver.
    • Remove the rubber O-ring by lifting it up.
  4. KitchenAid KSB5CR Circuit Board Replacement, Removing the Ribbon Cable: 手順 4、 1の画像 1
    • Remove the ribbon cable from the chassis by lifting it up.
    • Remove the other end of the ribbon cable from the circuit board by lifting it up.
  5. KitchenAid KSB5CR Circuit Board Replacement, Freeing the Power Cable: 手順 5、 1の画像 1
    • Lift up on the power cable to pop it out of its holder.
  6. KitchenAid KSB5CR Circuit Board Replacement, Detaching the White and Black Wires: 手順 6、 2の画像 1 KitchenAid KSB5CR Circuit Board Replacement, Detaching the White and Black Wires: 手順 6、 2の画像 2
    • Be gentle with the knife or you will break the circuit board.
    • Slide the knife into the metal loop holding the insulation before the white copper wire, and wiggle it back and forth until it loosens.
    • Pull the wire out from the metal loop that you loosened.
    • Repeat this process with the black copper wire.
  7. KitchenAid KSB5CR Circuit Board Replacement, Detatching the Green Wire: 手順 7、 2の画像 1 KitchenAid KSB5CR Circuit Board Replacement, Detatching the Green Wire: 手順 7、 2の画像 2
    • Using the Phillips #2 screwdriver, remove the #8 Phillips 6mm screw to which the green wire is attached.
  8. KitchenAid KSB5CR Circuit Board Replacement, Unscrewing the Circuit Board: 手順 8、 1の画像 1
    • Remove the #8 Phillips 12mm screws using the Phillips #2 screwdriver.
  9. KitchenAid KSB5CR Circuit Board Replacement, Removing the Circuit Board: 手順 9、 1の画像 1
    • Remove the circuit board by lifting it up.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Cameron Geehr
メンバー登録日: 09/28/14
745 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 12-5, Forte Fall 2014 Cal Poly, Team 12-5, Forte Fall 2014人のメンバー
CPSU-FORTE-F14S12G5
5 メンバー
6のガイドは作成済み
3 件のコメント
Hello, Thanks for video, very good! I see on my blender that main capacitor (blue one) has burned out. Could you tell me the value of it? is it on 110v? many thanks!
Hola, Muy bueno gracias. me voló el capacitor principal (azul grande) me podrías indicar de cuanto es? es para 110v? gracias!
Juan torres - 返信
I have already founded components that burn when plugged to 220v instead 110v. it was a varistor 14D201K, (circular blue), and also burn a thermal fusible besides (black cillinder) . 3A 250V. hope helps someone. thanks.
Juan torres - 返信
Hello, in my case I have lost the motor magnet, additionally the sensor is worn and I cannot see the reference, could you give me the sensor reference, and some idea of ​​how to replace the magnet.
hola, en mi caso he perdido el iman del motor, adicionalmente el sensor esta gastado y no logro ver la referencia, me podrias regalar la referencia del sensor, y alguna ida de como reemplazar el iman.
thank you so much
Miguel Ángel Bareño Bernal - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 24
今までの合計 2,461
