この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If your KitchenAid KBRS22KWMS6 fridge’s light bulb has completed its hours, use this guide to replace the bulb of your fridge.
A light bulb illuminates the interior of a fridge and can provide clear visibility of items inside. Having a fused bulb makes it difficult to find small items and can cause further problems.
Before using this guide, it is recommended to purchase an appliance light bulb as you will have everything nearby. If the type of lightbulb is unclear, refer to step 5 for more information. You may want to purchase two sets of light bulbs just in case one set results in being faulty or defective.
Before attempting this fix, make sure to unplug the fridge from its power outlet.
必要な工具と部品
ある他の人がこのガイドを完成しました。
