はじめに
This guide describes how to replace/clean a kitchen shut-off valve. The shut-off valve is responsible for shutting off the water flow towards the kitchen sink. Repairing a leakage and/or cleaning is very important as the shut-off valve is needed in order to maintain water flow and cleanliness. There are certain tools needed for this repair, the parts include the valve, the nut, the screw, the shut-off that connects to the pipe, and the stem kit.
必要な工具と部品
Ensure the main water supply is shut off to prevent any water from flowing while you start this repair.
Use the screwdriver to screw the valve back on. To do this, first insert the valve and then put the screw back into the socket. Then start tightening, but do not overtighten it, as it can damage the valve and/or the pipe.
Once completed, you have officially replaced/cleaned the kitchen shut-off valve. Good work!
