メインコンテンツにスキップ
Kingston HyperX CloudX Ear Pads Replacement
必要な工具と部品
  1. Kingston HyperX CloudX Ear Pads Replacement, Ear Pads: 手順 1、 1の画像 1
    • Place one finger on the inside of the cushion and place the other finger on the outer rim of the ear pad cushion.
    • Gently pull the ear pad away from the headset, removing the flap from the groove until the old ear pads are fully detached.
  2. Kingston HyperX CloudX Ear Pads Replacement: 手順 2、 1の画像 1
    • Take the new ear pad and slide the top side of the flap into the groove of the ear cup.
    • Once the flap is inside the groove, slide it all the way in to make sure the flap is secured inside the groove.
  3. Kingston HyperX CloudX Ear Pads Replacement: 手順 3、 1の画像 1
    • Squeeze the top part of the cushion into the earcup to keep it secure and prevent the flap from sliding out of the groove.
    • Make sure to keep a tight squeeze onto the cushion until it is fully secured onto the earcup to prevent the flap from slipping out.
  4. Kingston HyperX CloudX Ear Pads Replacement: 手順 4、 1の画像 1
    • Slowly start going around the outside of the earcup and stretching the cushion so that the flap is secured into the groove.
  5. Kingston HyperX CloudX Ear Pads Replacement: 手順 5、 2の画像 1 Kingston HyperX CloudX Ear Pads Replacement: 手順 5、 2の画像 2
    • Push the flap further into the groove by taking a spudger and going around the outside of the headset slowly pushing the spudger into the groove to make sure the flap is fully secured into the groove.
    • If you do not have a spudger, you can also use a credit card instead.
  6. Kingston HyperX CloudX Ear Pads Replacement: 手順 6、 1の画像 1
    • Squeeze the ear cushion and move it slightly back and forth to ensure the flap is secured.
    • Repeat on the other side.
ゴール
作成者
2人の作成者と共同で作成されました。
Sam Bloch
メンバー登録日: 03/01/23
133 ポイント
1ガイドが承認済み
チーム
University of Delaware, Team 12-4, McGuire Spring 2023 University of Delaware, Team 12-4, McGuire Spring 2023人のメンバー
UD-MCGUIRE-S23S12G4
5 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 12
過去 30 日: 50
今までの合計 499
