メインコンテンツにスキップ
はじめに
Vibration is a useful tool to ensure the user that a device is responding to the press of a button. This guide shows how to replace the vibrator in a Kindle Voyage should the device fail to vibrate properly.
パーツ
パーツは指定されていません。
  1. Kindle Voyage Vibrator Replacement, Back Panel: 手順 1、 2の画像 1 Kindle Voyage Vibrator Replacement, Back Panel: 手順 1、 2の画像 2
    • Insert a plastic opening tool between the plastic panel shown on the device.
    • Use the tool to pry the plastic away from the device.
    • There will be adhesive holding this piece of plastic to the device. You may have to pull pretty hard to get it separated.
    This is not the best way to do this. The plastic panel snaps in on the lower/center part and slides into notches in the top. When you do as this instructs it breaks the tabs that connect on the top. If you can slide a few of the guitar picks into the lower part and get all the glue disconnected and get it to get past the snaps on the bottom you can then slide it upward and remove it without damaging the panel.
    sam - 返信
  2. Kindle Voyage Vibrator Replacement: 手順 2、 1の画像 1
    • Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
  3. Kindle Voyage Vibrator Replacement: 手順 3、 3の画像 1 Kindle Voyage Vibrator Replacement: 手順 3、 3の画像 2 Kindle Voyage Vibrator Replacement: 手順 3、 3の画像 3
    • Once the screws are removed, the back panel can slide off the device.
    Why is step 4 needed? The magnetic component doesn’t appear to be in the way of the battery replacement. Is the magnetic component just sitting on the posts (without screws attaching)? Will any magnet work to remove it? Is there any electrical connection to this component?
    John - 返信
    There is no electrical connection, it is just sitting there. It should be removed so that it doesn’t fall out during the rest of the repair.
    Merlin04 - 返信
    I’ve tackled apparently more complicated jobs on iMac, MacBook and iPhone, but this one has defeated me! I can’t complete step 3 the panel simply will not slide off.
    Graham Miles - 返信
    Correction, tried some more. After one and a half hours of struggling I finally managed to slide the cover off. Now tht it’s been done once, it slides on and off easily.Just putting this here in case others have the same problem - persevere. In principle the job’s an easy one.
    Graham Miles - 返信
    If the old battery swells, as mine did, the board will not slide out of the case. Too much pressure exerted on the case from the swollen battery.
    I had to separate the two halves of the case.
    Robert Sauve - 返信
  4. Kindle Voyage Vibrator Replacement: 手順 4、 2の画像 1 Kindle Voyage Vibrator Replacement: 手順 4、 2の画像 2
    • Remove the magnetic component with the magnetic head of the aluminum driver.
    This instruction confused me. There is a component above the battery. It’s not held there by anything (no adhesive or fasteners), so you can just take it off. They’re saying to use anything magnetic to pick it up, but you can just use your fingers.
    moec - 返信
  5. Kindle Voyage Vibrator Replacement, Vibrator: 手順 5、 2の画像 1 Kindle Voyage Vibrator Replacement, Vibrator: 手順 5、 2の画像 2
    • Use tweezers to pinch in the sides of the vibrator cable and slide it out of its housing.
  6. Kindle Voyage Vibrator Replacement: 手順 6、 3の画像 1 Kindle Voyage Vibrator Replacement: 手順 6、 3の画像 2 Kindle Voyage Vibrator Replacement: 手順 6、 3の画像 3
    • Gently peel the vibrator off of the device.
終わりに
Sean Yap
メンバー登録日: 2015年01月22日
1,169 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 19-12, Maness Winter 2015 Cal Poly, Team 19-12, Maness Winter 2015人のメンバー
CPSU-MANESS-W15S19G12
5 メンバー
6のガイドは作成済み
コメント 1 件
OK, the procedure seems straightforward enough, but you say “no parts required” when you actually *do* need to buy the replacement parts for the pieces that are no longer functioning. Where can you buy these parts?
Sharon Crowley - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 12
今までの合計 1,076
