メインコンテンツにスキップ
Kindle Touch Rear Casing Replacement
必要な工具と部品
  1. Kindle Touch Rear Casing Replacement, Back Cover: 手順 1、 3の画像 1 Kindle Touch Rear Casing Replacement, Back Cover: 手順 1、 3の画像 2 Kindle Touch Rear Casing Replacement, Back Cover: 手順 1、 3の画像 3
    • Use the plastic opening tool to undo the ten plastic clips around the back panel of the Kindle.
  2. Kindle Touch Rear Casing Replacement: 手順 2、 2の画像 1 Kindle Touch Rear Casing Replacement: 手順 2、 2の画像 2
    • Gently lift the bottom and slide the panel off.
  3. Kindle Touch Rear Casing Replacement, Battery: 手順 3、 3の画像 1 Kindle Touch Rear Casing Replacement, Battery: 手順 3、 3の画像 2 Kindle Touch Rear Casing Replacement, Battery: 手順 3、 3の画像 3
    • Use a Phillips #00 screwdriver to remove the five screws.
  4. Kindle Touch Rear Casing Replacement: 手順 4、 3の画像 1 Kindle Touch Rear Casing Replacement: 手順 4、 3の画像 2 Kindle Touch Rear Casing Replacement: 手順 4、 3の画像 3
    • Using the flat end of your spudger, gently pry the battery up and remove it.
  5. Kindle Touch Rear Casing Replacement, Bezel: 手順 5、 2の画像 1 Kindle Touch Rear Casing Replacement, Bezel: 手順 5、 2の画像 2
    • Using a Phillips #00 screwdriver, remove the six 4 mm screws to access the front plate.
  6. Kindle Touch Rear Casing Replacement: 手順 6、 3の画像 1 Kindle Touch Rear Casing Replacement: 手順 6、 3の画像 2 Kindle Touch Rear Casing Replacement: 手順 6、 3の画像 3
    • Use the plastic opening tool to pry the bezel from the top and sides
    • The bottom of the bezel will be glued, so be careful when sliding the clips out.
    • The clips can be easily bent, so do not try to force them out. If you do bend some, they can be bent back.
  7. Kindle Touch Rear Casing Replacement, Rear Casing: 手順 7、 1の画像 1
    • Use your Phillips #00 srewdriver to remove the indicated screws.
    • There are three pairs of screws that are each different. The screws on the top corners are 4 mm #00 Phillips screws, the screws on the bottom corners are 2 mm #00 Phillips screws, and the black bottom center screws are 6 mm #00 Phillips screws.
  8. Kindle Touch Rear Casing Replacement: 手順 8、 2の画像 1 Kindle Touch Rear Casing Replacement: 手順 8、 2の画像 2
    • With the screws removed, gently remove the case from the internals.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Adam Yerly
メンバー登録日: 01/20/15
1,933 ポイント
7のガイドは作成済み
チーム
USF Tampa, Team 19-5, Blackwell Winter 2015 USF Tampa, Team 19-5, Blackwell Winter 2015人のメンバー
USFT-BLACKWELL-W15S19G5
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 19
今までの合計 1,202
