メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Kindle Paperwhite 2nd Generation Motherboard Replacement
必要な工具と部品
  1. Kindle Paperwhite 2nd Generation Motherboard Replacement, Battery: 手順 1、 2の画像 1 Kindle Paperwhite 2nd Generation Motherboard Replacement, Battery: 手順 1、 2の画像 2
    • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
    • Be sure to begin prying along the outer edges , these are the optimal points for removing the bezel.
    • Be careful and do not slide prying tool deeper than 3-4 mm under the side bezel or you could peel off screen protector film.
  2. Kindle Paperwhite 2nd Generation Motherboard Replacement: 手順 2、 2の画像 1 Kindle Paperwhite 2nd Generation Motherboard Replacement: 手順 2、 2の画像 2
    • Using a Screw Driver, Remove the eleven 3.2 mm Phillips 000 screws from corners of the mid-frame and from behind the black strip as shown.
    • Do not forget the screw in the middle of the black adhesive strip.
  3. Kindle Paperwhite 2nd Generation Motherboard Replacement: 手順 3、 1の画像 1
    • Carefully remove the mid-frame from the back cover.
  4. Kindle Paperwhite 2nd Generation Motherboard Replacement: 手順 4、 2の画像 1 Kindle Paperwhite 2nd Generation Motherboard Replacement: 手順 4、 2の画像 2
    • Use a screwdriver to remove the three 3.0 mm Phillips 000 screws that are holding the battery in place as shown.
  5. Kindle Paperwhite 2nd Generation Motherboard Replacement: 手順 5、 1の画像 1
    • Carefully lift the battery and remove it from the device.
  6. Kindle Paperwhite 2nd Generation Motherboard Replacement, Motherboard: 手順 6、 2の画像 1 Kindle Paperwhite 2nd Generation Motherboard Replacement, Motherboard: 手順 6、 2の画像 2
    • Use a screwdriver to remove the seven 3.0 mm Phillips 000 screws that are holding the motherboard in place as shown.
    • Don't lose the washer that is highlighted with an orange marker as shown. It is a necessary component to protect the screw.
  7. Kindle Paperwhite 2nd Generation Motherboard Replacement: 手順 7、 2の画像 1 Kindle Paperwhite 2nd Generation Motherboard Replacement: 手順 7、 2の画像 2
    • Gently disconnect the zif connectors.
    • Some of these connectors are very thin and fragile, handle with care!
  8. Kindle Paperwhite 2nd Generation Motherboard Replacement: 手順 8、 3の画像 1 Kindle Paperwhite 2nd Generation Motherboard Replacement: 手順 8、 3の画像 2 Kindle Paperwhite 2nd Generation Motherboard Replacement: 手順 8、 3の画像 3
    • Gently remove the motherboard.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Tyler Davis
メンバー登録日: 09/15/16
1,932 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 11-2, Blackwell Fall 2016 USF Tampa, Team 11-2, Blackwell Fall 2016人のメンバー
USFT-BLACKWELL-F16S11G2
4 メンバー
20のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 21
過去 30 日: 94
今までの合計 4,551
