はじめに
Kindle Paperwhite 第1世代のマザーボードを交換するための修理ガイドです。
必要な工具と部品
ミッドフレームを固定している3.0mmプラスネジを11本外します。
Hello, the original battery is 1420m Ah and 3.7VDC, but the buttery you offer to sell is 1600mAh, is it right? there is no problem with different mAh? mi kindle is the amazon kindle 1est generation
バッテリーの下側から慎重に持ち上げて、ミッドフレームからスライドして取り出します。
Thanks for providing this guide, I would have been lost without it. My old kindle, however, had very stiff and hard rubber/plastic. There was no way I could have slid the glass to the side or gotten the plastic spud under the edge of the glass or the plastic.
What I did was to remove a piece of the plastic next to the glass , about 1/8” square, then insert a putty knife in between the two sides towards the edges. It all popped apart without breaking anything. Perhaps I could have done this without cutting out the little piece.
Thank you for this very user friendly guide.My kindle is now working as new.The screws are small and fiddly and the correct tools are essential. I took roughly about 45 minutes from start to finish and the most difficult part was taking the casing apart without damaging the screen .. A 5 star service.
The bezel sits on a film meant to protect the screen. When lifting the bezel, it is a good idea to slightly push on the screen with cardboard or something elese, to make sure the screen film stays on the screen as you lift the bezel.
スパッジャーを使って、白い固定ケーブルのテンショナーを持ち上げて、フレックスケーブルを引き抜きます。
反時計回りに次のケーブルに移って、同じ作業を繰り返します。下側にある小さなフレックスケーブルはケーブルのテンショナーを持ち上げる必要はありません。ただ、慎重に引き抜いてください。
The second connector is not exactly a "repeat". The lock to be lifted is on the cable side, whereas the first connector's lock is away from the cable.
デバイスを再組立する際は、これらのインストラクションを逆の順番に従って作業を進めてください。
6 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
2 件のコメント
Not sure if this is an error, but on the 3G paperwhite, we needed to use a #0 Phillips, not a #2. Great guide otherwise!
I found it easier to start this step off with one of the Opening Picks found in the iOpener pack.
NathanF - 返信
The glue on bezel started to peel the sticky back protective layer off the screen for me - managed to smooth it back down, although now have an unsightly crease. I would try to hold the screen down when you pull the bezel off to stop damaging the screen.
Callum Rogers - 返信
This step is most time consuming. Take you time and try not to scratch the bezel :)
Oleksii - 返信
Couldn't get the plastic spudger under the edge of the bezel. A right-angle X-Acto blade was a satisfactory tool here.
dbrick - 返信
The glue was VERY difficult...I used a trick, from taking apart phones, and used a hair drier to loosen up the glue...worked like a charm.
billkaris - 返信
