メインコンテンツにスキップ
Kindle Fire Power Button Board Replacement
必要な工具と部品
  1. Kindle Fire Power Button Board Replacement, Back Case: 手順 1、 3の画像 1 Kindle Fire Power Button Board Replacement, Back Case: 手順 1、 3の画像 2 Kindle Fire Power Button Board Replacement, Back Case: 手順 1、 3の画像 3
    • Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
    • Pry the case apart and run the plastic opening tool along the perimeter of the Kindle Fire to release the clips securing the case halves to each other.
    • If you are having extreme difficulty inserting the plastic opening tool, carefully use a metal spudger to undo the first clip, then switch back to the opening tool to avoid scratching your case.
    • It is helpful to pry the bottom of the Kindle Fire away (and out from the side) from the top part. Exerting too much force attempting to split the two without pulling away can cause the tabs on the inside to crack.
    Where can I buy a battery for my kindle fire
    nannyto2 - 返信
    Try EBay or Amazon. make sure you get the right battery for your Kindle , one is for a Kindle HD and the older version........both are 7 ".
    vvenona1954 - 返信
    Remember to remove any sd card first!!! Snapped mine in half.
    lucy_lady_bug - 返信
    I have the first kindle that came out and it doesn't have the same setup how can I open the back of my kindle?
    Kris Sanders - 返信
  2. Kindle Fire Power Button Board Replacement: 手順 2、 1の画像 1
    • Once you have freed all the plastic clips, pull the back case off the Kindle Fire.
    Mine has another plastic pc over the m.etal plate
    Keith Long - 返信
  3. Kindle Fire Power Button Board Replacement, Battery: 手順 3、 3の画像 1 Kindle Fire Power Button Board Replacement, Battery: 手順 3、 3の画像 2 Kindle Fire Power Button Board Replacement, Battery: 手順 3、 3の画像 3
    • Fit the tip of the plastic opening tool between the right battery cell and the Kindle Fire's frame.
    • Lever the battery up and work the plastic opening tool down along its edge to release the glue securing it to the frame.
  4. Kindle Fire Power Button Board Replacement: 手順 4、 1の画像 1
    • Repeat the process from the previous step to free the left battery cell.
    The CPU got extremely hot and just now getting repaired 5 days or so
    Kelli Sabashion - 返信
    I can't get the battery to charge
  5. Kindle Fire Power Button Board Replacement: 手順 5、 2の画像 1 Kindle Fire Power Button Board Replacement: 手順 5、 2の画像 2
    • Lift the back of the battery up to relieve any tension in the battery connector and simultaneously use a spudger to push the battery connector out of its socket.
    • Pull the battery out of the Kindle Fire.
  6. Kindle Fire Power Button Board Replacement, Motherboard: 手順 6、 3の画像 1 Kindle Fire Power Button Board Replacement, Motherboard: 手順 6、 3の画像 2 Kindle Fire Power Button Board Replacement, Motherboard: 手順 6、 3の画像 3
    • Remove the two 2.3 mm Phillips #00 screws from the touchscreen controller.
    • Use a plastic opening tool to release the touchscreen controller connector.
    • Gently remove the touchscreen controller by lifting it up and to the right.
    • Be careful not to rip the ribbon cable in doing so.
  7. Kindle Fire Power Button Board Replacement: 手順 7、 3の画像 1 Kindle Fire Power Button Board Replacement: 手順 7、 3の画像 2 Kindle Fire Power Button Board Replacement: 手順 7、 3の画像 3
    • Use a plastic opening tool to flip open the power button ZIF connector.
    • This connector will not be removed until the motherboard is free.
    • Flip open the ambient light sensor ZIF socket with a plastic opening tool.
    • Use a pair of tweezers to pull the blue tab on the ambient light sensor cable to remove it from its socket.
    Make sure to mark what ZIF connector goes where, they are not interchangeable even though a first glance the appear to be the same size
    David Alvarez - 返信
    It took about 2 hours, but that is, mainly, because reconnecting the ZIF connectors can be overly tedios.
    David Alvarez - 返信
    Apparently not all Kindle Fires have the ambient light sensor; This connector is not present on mine.
    diprosew - 返信
    I cannot get the zif connectors to go back in ..what can i do...been trying for hours to get them back in...im talking bout the white flip pieces that lock in film..some one please help me with this!!
    bearangel246 - 返信
    Stand it up on its end, lining up the holes to the wires. Slide into holes and 'flip'/rotate white plastic piece down into a flat position.
    toniamosley -
  8. Kindle Fire Power Button Board Replacement: 手順 8、 3の画像 1 Kindle Fire Power Button Board Replacement: 手順 8、 3の画像 2 Kindle Fire Power Button Board Replacement: 手順 8、 3の画像 3
    • Use a plastic opening tool to lift up and disconnect the display data cable.
    • Lift up on the antenna connector with a plastic opening tool to disconnect it.
    • De-route the antenna cable.
    Be very careful when disconnecting the antenna, and be sure to note how the cable is routed into the little socket on the motherboard. The reconnecting of the antenna cable into its motherboard port can be tricky and will require patience, persistence and perhaps a magnifier and tweezers.
    Jeff Jones - 返信
    note that the image still displays the speakers that were supposed to be removed in an earlier step
    diprosew - 返信
    Followed the steps but once reassembled the screen comes on but doesn't respond to touch. It was working fine even with broken glass screen. Any suggestions?
    John Moore - 返信
    Mine is doing the same thing! What did you do to fix it?
    Tara -
    I order a replacement motherboard from ifixit and for some reason it had a plastic increasing around the outer edge of the "display data cable connection port" on the motherboard, which makes it impossible to connect the cable to the motherboard. I called ifixit and they said send a picture and a description. Hopefully the customer who owns the kindle fire will understand that after waiting on the part for a week. :\
    nuban1990 - 返信
    Mine no longer responded to touch!!!!! Why did we all have the same problem on reassembly after changing charging port?
    gregk8776 - 返信
  9. Kindle Fire Power Button Board Replacement: 手順 9、 1の画像 1
    • Remove the six 2.6 mm Phillips #00 screws securing the motherboard to the frame.
  10. Kindle Fire Power Button Board Replacement: 手順 10、 3の画像 1 Kindle Fire Power Button Board Replacement: 手順 10、 3の画像 2 Kindle Fire Power Button Board Replacement: 手順 10、 3の画像 3
    • Use a plastic opening tool to gently lever up the bottom side of the motherboard to free from the adhesive on its underside.
    • Lever the top side of the motherboard up with a plastic opening tool until it comes free.
    • Lift the motherboard out of the Kindle Fire, making sure that the power button cable from step 8 comes free from its connector.
  11. Kindle Fire Power Button Board Replacement, Power Button Board: 手順 11、 2の画像 1 Kindle Fire Power Button Board Replacement, Power Button Board: 手順 11、 2の画像 2
    • Remove the 2.5 mm Phillips #00 scew securing the power button board to the Kindle Fire.
    • Lift the power button board out of the Kindle Fire.
終わりに
18 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Phillip Takahashi
メンバー登録日: 08/22/11
86,686 ポイント
87のガイドは作成済み
コメント 1 件
This PCB does not contain the power button, only the power LED. The button is located on the main PCB next to the USB port.
jcross1986 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 15
過去 30 日: 56
今までの合計 33,140
