はじめに
このガイドを使って、Kindle Fire HDX 7インチタブレットのマザーボードを交換します。
マザーボードを取り出して初めて、バッテリーの接続を外せます。メタルツールでマザーボード上のコンポーネント周辺をショートしないように注意してください。
必要な工具と部品
ピンセットで黄色のテープをつまんで、プレスフィットのコネクタを上向きに引っ張って接続を外します。
マザーボードから3mm T6トルクスネジを9本外します。
What is that black tape holding the antenna called? It is metallic on the other side. I dont think mine will re-stick is there something else I can use or do I need to find the same stuff? For this Kindle, reversing your steps doesnt quite work if you dont know what tapes and adhesives to get to close it up. I found the yellow tape is called a heat transfer tape but I still have no idea what double sided adhesive to get to mount the screen/digitizer assembly and bezel back on. Dont think Ill be putting any back on the battery and dont think I want it to be as difficult as the original, any suggestions please? Im stuck at this step and am having trouble finding the answer anywhere!
デバイスを再組み立てする際は、これらの手順を逆の順番に従って作業を進めてください。
ある他の人がこのガイドを完成しました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
2 件のコメント
This is a good tutorial but there is no mention of the bottom two connectors attached to the motherboard and some tips on reattaching these, i.e. the connector cables can be extended and then pulled back to normal to make reattachment possible
Exactly! Followed this tutorial today, wanted to replace motherboard, and almost ripped off the lcd/touch connectors and flat cables because didn’t know they are there. It’s a bit difficult to put them back, be careful.
Neb Sek -
