メインコンテンツにスキップ
Kindle Fire Back Case Replacement
必要な工具と部品
  1. Kindle Fire Back Case Replacement, Back Case: 手順 1、 3の画像 1 Kindle Fire Back Case Replacement, Back Case: 手順 1、 3の画像 2 Kindle Fire Back Case Replacement, Back Case: 手順 1、 3の画像 3
    • Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
    • Pry the case apart and run the plastic opening tool along the perimeter of the Kindle Fire to release the clips securing the case halves to each other.
    • If you are having extreme difficulty inserting the plastic opening tool, carefully use a metal spudger to undo the first clip, then switch back to the opening tool to avoid scratching your case.
    • It is helpful to pry the bottom of the Kindle Fire away (and out from the side) from the top part. Exerting too much force attempting to split the two without pulling away can cause the tabs on the inside to crack.
  2. Kindle Fire Back Case Replacement: 手順 2、 1の画像 1
    • Once you have freed all the plastic clips, pull the back case off the Kindle Fire.
終わりに
14 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Phillip Takahashi
メンバー登録日: 08/22/11
86,704 ポイント
87のガイドは作成済み
3 件のコメント
Simple to follow instructions .
Eric Rester - 返信
where to buy the base panel for my kindle fire 7 tablet
Senthilvel Murugesan - 返信
I was wondering why my kindle case was opening/separating and it was not charging. I opened the case per you instructions and found that the battery has expanded inside ITS case! I hope to be able to get another battery cheaply. Thank you for your help!!
Ellen De - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 61
今までの合計 15,922
