メインコンテンツにスキップ
Kindle Fire 1st Generation Motherboard Replacement
必要な工具と部品
  1. Kindle Fire 1st Generation Motherboard Replacement, Removing The Back Cover: 手順 1、 2の画像 1 Kindle Fire 1st Generation Motherboard Replacement, Removing The Back Cover: 手順 1、 2の画像 2
    • May need to use something to pry it open such as a screwdriver.
    • After you pop some of the little clips inside, you can use your fingers to remove it completely.
  2. Kindle Fire 1st Generation Motherboard Replacement, Locating Part Number: 手順 2、 3の画像 1 Kindle Fire 1st Generation Motherboard Replacement, Locating Part Number: 手順 2、 3の画像 2 Kindle Fire 1st Generation Motherboard Replacement, Locating Part Number: 手順 2、 3の画像 3
    • The first photo shows two red circles over the screw that will need to be removed first.
    • After lifting the tab as shown in the third photo you will need the part number located below bar code.
  3. Kindle Fire 1st Generation Motherboard Replacement, Remove All Tabs: 手順 3、 1の画像 1
    • Next you will need remove all of the little white sliders that hold tabs down. if your fingernails are any shorter than mine you may need to use something for assistance.
  4. Kindle Fire 1st Generation Motherboard Replacement, Remove All Wires: 手順 4、 3の画像 1 Kindle Fire 1st Generation Motherboard Replacement, Remove All Wires: 手順 4、 3の画像 2 Kindle Fire 1st Generation Motherboard Replacement, Remove All Wires: 手順 4、 3の画像 3
    • Remove all of the wires that trace to the mother board.
    • Two speaker wires
    • Wire for battery
  5. Kindle Fire 1st Generation Motherboard Replacement, Removing The Last Few Pieces: 手順 5、 3の画像 1 Kindle Fire 1st Generation Motherboard Replacement, Removing The Last Few Pieces: 手順 5、 3の画像 2 Kindle Fire 1st Generation Motherboard Replacement, Removing The Last Few Pieces: 手順 5、 3の画像 3
    • Using your fillips screwdriver, remove the screws that have red circles around them.
    • The screws that have blue circles around them should already be removed at this point but there are two remaining screws under that tab that also need to be removed.
    • In addition, use your fingers to remove the tab that has a purple square around it.
  6. Kindle Fire 1st Generation Motherboard Replacement, Pull The Mother Board Out: 手順 6、 1の画像 1
    • Pull the motherboard out and order the part.
終わりに
作成者
2人の作成者と共同で作成されました。
Reed
メンバー登録日: 03/06/18
133 ポイント
1ガイドが承認済み
チーム
Vegas Room H9 Vegas Room H9人のメンバー
Community
13 メンバー
17のガイドは作成済み
コメント 1 件
Hey! how did you manage to pry the back off?
Ben Sommer - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 5
過去 30 日: 20
今までの合計 452
