必要な工具と部品
ブルーのプラスチック開口ツールを使って、各コーナーのクリップを外して、フロントパネルの接着剤を剥がします。
ツールを継ぎ目に沿ってスライドして、フロントパネルをこじ開けます。
フロントパネルを剥がして、Kindleより取り出します。
フロントパネルを破損しないように、パネルをコーナーからKindle中央に向けて剥がします。
What is the adhesive you are using resecure the screen? Would Tesa 61395 Tape work (4mm) or would this create protrusion?
Did that option work for you? I'm about to try and change my battery and don't have any idea on what backup adhesive to have
Lagroth -
T5トルクスドライバーで、 5.0 mmプラスネジを10本外します。
You will break the newer vision of kindle just like this. there is a peg that connect the top center of the screen to the back case. Remove the black double sided tape in the center and push this peg back .
If you see black double sided tape at the top of your Kindle, as the commenter above did, you are on the wrong model—have a look here to see if this is your model: Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement
スクリーンを裏返して、マザーボードとバッテリーパックを表に配置します。
先端が鋭利でないピンセットを使って、バッテリーパックとマザーボードに接続されたケーブルのクリップを慎重に外します。
デバイスを再組み立てする際は、これらの手順を逆の順番に従って作業を進めてください。
4 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
3 件のコメント
This doesn’t look like my 7th generation. Close but not quite the same. Does the motherboard have to be removed to replace the screen?
yes this is Def not the same as my 7th gen but it's an 8 inch so maybe that's the difference.. all I see is 4 screws holding down the motherboard n I've removed them but still can't get the board loose.. it's like one side of it is held down under these plastic tabs that don't move..
i had a battery that wouldn't even last a full day in the end. by accident i let the battery fall below 10% charge and when turned on it only showed the battery icon. I fully charged it and now i am having no problems with it. what i think happened is it reset the batteries memory and that was the problem. worth trying anyway before buying a new battery.
soupamanx - 返信
