はじめに
Installing a new motherboard takes quite a bit of disassembling. However, if you follow the steps in this guide, you should have no trouble at all.
ツール
パーツ
パーツは指定されていません。
Lay the Kindle face down on a soft cloth to protect its screen.
Wedge the plastic opening tool in the small opening between the grey plastic and the metal casing.
Move the plastic opening tool across the opening while pressing down to separate the grey plastic from the metal casing.
Slide the gray plastic top piece away from the Kindle's metal casing.
Use a Phillips #00 screwdriver to remove the two 2mm screws from the wireless card.
ある他の人がこのガイドを完成しました。
