メインコンテンツにスキップ
Kindle 1st Generation ON/OFF Power and Wifi Switches Replacement
必要な工具と部品
  1. Kindle 1st Generation ON/OFF Power and Wifi Switches Replacement, Battery: 手順 1、 1の画像 1
    • Slide the grey plastic cover laterally off the back of the device.
  2. Kindle 1st Generation ON/OFF Power and Wifi Switches Replacement: 手順 2、 2の画像 1 Kindle 1st Generation ON/OFF Power and Wifi Switches Replacement: 手順 2、 2の画像 2
    • Use a plastic opening tool to lift the battery on the side closest to the edge of the device.
    • Unplug the battery from the device by pinching the white connector and pulling.
    • Do not yank the battery or try to disconnect the battery by pulling the wires.
  3. Kindle 1st Generation ON/OFF Power and Wifi Switches Replacement, ON/OFF Power and Wifi Switches: 手順 3、 1の画像 1
    • Unscrew eight (8) Phillips #00 screws (3 mm).
  4. Kindle 1st Generation ON/OFF Power and Wifi Switches Replacement: 手順 4、 2の画像 1 Kindle 1st Generation ON/OFF Power and Wifi Switches Replacement: 手順 4、 2の画像 2
    • Start at one side of the device. Use a soft plastic prying tool to separate the casing of the device. Slowly work your way around the entire device.
    • Avoid prying between the buttons and the device. This could cause damage to the buttons.
  5. Kindle 1st Generation ON/OFF Power and Wifi Switches Replacement: 手順 5、 2の画像 1 Kindle 1st Generation ON/OFF Power and Wifi Switches Replacement: 手順 5、 2の画像 2
    • Unscrew the two (2) Phillips #00 screws (3 mm) which fasten the metal casing shield.
    • Slowly remove the metal casing shield by lifting it and carefully peeling up the tape.
  6. Kindle 1st Generation ON/OFF Power and Wifi Switches Replacement: 手順 6、 1の画像 1
    • Remove the two (2) Phillips #00 screws (3 mm) which fasten the ON/OFF Power and Wifi Switches to the device.
  7. Kindle 1st Generation ON/OFF Power and Wifi Switches Replacement: 手順 7、 2の画像 1 Kindle 1st Generation ON/OFF Power and Wifi Switches Replacement: 手順 7、 2の画像 2
    • Lift the flap attaching the blue and white ribbon cable to the motherboard by lifting it vertically with the pointed-end of the spudger.
    • The flap is connected via a hinge. Once you lift the flap, it will stay up and the cable will be lose. Remember to snap it back down during reassembly.
    • Carefully lift the ON/OFF Power and Wifi Switch vertically from the device motherboard.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Samantha Manning
メンバー登録日: 06/04/13
766 ポイント
6のガイドは作成済み
チーム
University of Kentucky Louisville, Team 1-1, Chamberlain Spring 2013 University of Kentucky Louisville, Team 1-1, Chamberlain Spring 2013人のメンバー
LOUISVILLE-CHAMBERLAIN-S13S1G1
2 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 18
今までの合計 2,020
