はじめに
If your Kidzlane Walkie-Talkie is having issues with static or lost signals, use this guide to replace the antenna.
The antenna in the walkie-talkie is used to help extend the range of your two-way radio.
Step 4 requires you to use a soldering device to melt down the antenna before removing it from the circuit board. Let the soldering device heat up before starting the project. If you would like information on soldering because you aren't experienced or would like a refresher, check out this guide.
Before beginning, make sure to have the walkie-talkie's power source switched to the "off" position.
必要な工具と部品
Flip the green circuit board over, so that the end of the antenna is visible. Use the soldering iron to disconnect the antenna.
Carefully remove the antenna from the circuit board.
To reassemble your Kidzlane Walkie-Talkie, follow these instructions in reverse order.
2 の人々がこのガイドを完成させました。
