メインコンテンツにスキップ
Kid Motorz Xtreme Quad 12V Vehicle Battery Repair
必要な工具と部品
  1. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair, Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: 手順 1、 1の画像 1
    • Remove the screw at the back of the seat.
    • Remove the seat from the device.
  2. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: 手順 2、 1の画像 1
    • Remove the two screws along the bracket.
    • Remove the bracket.
  3. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: 手順 3、 1の画像 1
    • Disconnect battery by gently pushing the tabs inwards and carefully unplugging it.
  4. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: 手順 4、 2の画像 1 Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: 手順 4、 2の画像 2
    • Remove the battery terminals and the battery.
  5. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: 手順 5、 1の画像 1
    • Put safety gloves on before beginning to solder.
    • Take your solder and place it carefully on the terminal points of the battery (negative and positive).
  6. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: 手順 6、 1の画像 1
    • Apply heat to the solder.
  7. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: 手順 7、 2の画像 1 Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: 手順 7、 2の画像 2
    • Position the wire onto the end piece and apply heat to the solder.
  8. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: 手順 8、 2の画像 1 Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: 手順 8、 2の画像 2
    • Put the battery back into its compartment.
    • Plug the battery back in.
  9. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: 手順 9、 1の画像 1
    • Place the bracket back into its slot.
    • Screw the bracket screws back into place.
  10. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: 手順 10、 1の画像 1
    • Place the seat back onto the device.
    • Screw the seat screw back into place.
  11. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: 手順 11、 1の画像 1
    • Congratulations you are now ready to ride again!
終わりに
The goal of this guide is to repair a battery terminal through solder and after completing the guide you should be able to apply what you learned to other projects and similar electronics
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Yanal
メンバー登録日: 02/20/23
243 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team Z-99, Cameron Spring 2023 University of Memphis, Team Z-99, Cameron Spring 2023人のメンバー
UM-CAMERON-S23SZG99
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 15
今までの合計 168
