メインコンテンツにスキップ
Kid Galaxy Morphibians Explorer Outer Cover Replacement
必要な工具と部品
  1. Kid Galaxy Morphibians Explorer Outer Cover  Replacement, Remove the Top Cover: 手順 1、 1の画像 1
    • First, completely loosen the 9.6 mm Phillips #2 screw on top. There is a plastic washer that holds the screw to the top cover, so it will not need to be taken out.
  2. Kid Galaxy Morphibians Explorer Outer Cover  Replacement: 手順 2、 1の画像 1
    • After the screw has been loosened, lift the cover off.
  3. Kid Galaxy Morphibians Explorer Outer Cover  Replacement: 手順 3、 1の画像 1
    • Completely loosen the 9.6 mm Phillips #2 screw from the battery cover. Once again, there is a plastic washer to hold the screw to the cover.
  4. Kid Galaxy Morphibians Explorer Outer Cover  Replacement: 手順 4、 1の画像 1
    • After the screw is loosened, lift the battery cover off the top cover to gain access to the batteries.
    • Turn the RC car over to reach the six screws on the bottom.
  5. Kid Galaxy Morphibians Explorer Outer Cover  Replacement: 手順 5、 1の画像 1
    • Remove the six 11.6 mm Phillips #2 screws on the bottom cover.
    • (Wheels are removed in this picture to clearly show screw location. They do not need to be removed for this step)
  6. Kid Galaxy Morphibians Explorer Outer Cover  Replacement: 手順 6、 1の画像 1
    • Lift the top Cover off the car.
終わりに
作成者
5人の作成者と共同で作成されました。
Eric Studstrup
メンバー登録日: 09/22/14
4 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 1-2, Hickman Fall 2014 USF Tampa, Team 1-2, Hickman Fall 2014人のメンバー
USFT-HICKMAN-F14S1G2
3 メンバー
7のガイドは作成済み
コメント 1 件
As i can see in the last image. There are some wires still connected with the outer cover. Could have shown couple more images how to get them off. Everything else looks great.
Dishant Patel - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 206
