1. Turn the controller over to the backside and locate the battery cover screw.
    • Turn the controller over to the backside and locate the battery cover screw.
  2. The battery cover 8.0mm Phillips #2 screw is on the bottom left handle. There is a plastic washer holding the screw to the cover, so completely loosen the screw, but do not remove.
    • The battery cover 8.0mm Phillips #2 screw is on the bottom left handle. There is a plastic washer holding the screw to the cover, so completely loosen the screw, but do not remove.
  3. Once the screw is removed lift the battery cover up from the controller.
    • Once the screw is removed lift the battery cover up from the controller.
  4. Remove the 2 AA batteries.
    • Remove the 2 AA batteries.
  5. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  6. Remove both the 6.0mm Phillips #1 screws holding the D-pads in place.
    • Remove both the 6.0mm Phillips #1 screws holding the D-pads in place.
  7. Insert wisdom here.
    • Insert wisdom here.
  8. Remove the four  8.1 Phillips #1 screws (red:) and (orange:)
    • Remove the four 8.1 Phillips #1 screws (red:) and (orange:)
  9. Lift the antenna holder away from the controller towards the top of the antenna.
    • Lift the antenna holder away from the controller towards the top of the antenna.
  10. Before you separate both halves of the controller make sure the battery holder is facing you so the D-pads stay in place.
    • Before you separate both halves of the controller make sure the battery holder is facing you so the D-pads stay in place.
    • Separate both halves of the controller.
  11. Remove the 7.9 Phillips #1 screw that holds both the antenna and the internal chip.
    • Remove the 7.9 Phillips #1 screw that holds both the antenna and the internal chip.
  12. Remove the internal chip by pulling it away from the controller.
    • Remove the internal chip by pulling it away from the controller.
    • Remove both the positive(red wire) and negative(black wire) from the battery terminals.
    • Reverse the steps to put everything back together.
まとめ
Rusbell Gonzalez
メンバー登録日: 2014年09月17日
219 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 1-2, Hickman Fall 2014 USF Tampa, Team 1-2, Hickman Fall 2014人のメンバー
USFT-HICKMAN-F14S1G2
3 メンバー
7のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 109
