メインコンテンツにスキップ
Kicker CXA300.1 Capacitor Replacement
必要な工具と部品
  1. Kicker CXA300.1 Capacitor Replacement, Capacitor: 手順 1、 1の画像 1
    • Remove the five T10 Torx screws from the housing.
  2. Kicker CXA300.1 Capacitor Replacement: 手順 2、 1の画像 1
    • Remove the two T10 Torx screws from the faceplate.
  3. Kicker CXA300.1 Capacitor Replacement: 手順 3、 2の画像 1 Kicker CXA300.1 Capacitor Replacement: 手順 3、 2の画像 2
    • Remove the six T10 Torx screws from the bottom.
    • Pull off the bottom.
  4. Kicker CXA300.1 Capacitor Replacement: 手順 4、 1の画像 1
    • Desolder the capacitor and remove.
    • Refer to iFixit’s soldering guide to reattach capacitor.
終わりに
作成者
3人の作成者と共同で作成されました。
Tim Keptya
メンバー登録日: 04/12/18
546 ポイント
4のガイドは作成済み
チーム
UW Tacoma, Team S1-G3, Liner Spring 2018 UW Tacoma, Team S1-G3, Liner Spring 2018人のメンバー
UWT-LINER-S18S1G3
3 メンバー
4のガイドは作成済み
コメント 1 件
Are you out of your mind or was this a late April Fools joke?!? That is NOT how you replace a capacitor, all you did was tear one off the board and take pictures of the carnage.
To replace a through-hole or snap-in capacitor you need to remove the board from the heat sink and (de)solder on the under side. In addition, proper selection of your replacement parts is crucial to the long-term viability of your repair.
If you are replacing a leaky/ruptured capacitor (or in this case, one that’s been torn off the board by a caveman) it’s critical to thoroughly clean any areas of the board and all components that were exposed to the electrolyte. The electrolyte in electrolytic capacitors is corrosive and will destroy the circuit board if it is not removed.
Tim, I encourage a response. Lets get some dialogue going.
Matt - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 17
今までの合計 871
