メインコンテンツにスキップ
Keurig K10 MINI PLUS Top Needle Replacement
必要な工具と部品
  1. Keurig K10 MINI PLUS Top Needle Replacement, Cup Holder: 手順 1、 3の画像 1 Keurig K10 MINI PLUS Top Needle Replacement, Cup Holder: 手順 1、 3の画像 2 Keurig K10 MINI PLUS Top Needle Replacement, Cup Holder: 手順 1、 3の画像 3
    • Press on tab while pulling up on K-cup until you hear a click. Repeat for the remaining tabs. We found using the smallest of the "plastic opening tools" worked wonders.
  2. Keurig K10 MINI PLUS Top Needle Replacement: 手順 2、 2の画像 1 Keurig K10 MINI PLUS Top Needle Replacement: 手順 2、 2の画像 2
    • Once all of the tabs have been pressed, the K-Cup should just pop out. After, you just pull the remainder of the K-Cup. You have successfully removed the K-Cup.
  3. Keurig K10 MINI PLUS Top Needle Replacement, Top Needle: 手順 3、 2の画像 1 Keurig K10 MINI PLUS Top Needle Replacement, Top Needle: 手順 3、 2の画像 2
    • Remove two 9 mm Phillips #1 screws.
    • Avoid the top needle if at all possible. The needle may cut you and/or penetrate your skin.
    • The screws are located on the top of where the K-Cup would be.
  4. Keurig K10 MINI PLUS Top Needle Replacement: 手順 4、 3の画像 1 Keurig K10 MINI PLUS Top Needle Replacement: 手順 4、 3の画像 2 Keurig K10 MINI PLUS Top Needle Replacement: 手順 4、 3の画像 3
    • Once you remove the screws, the top cover should come out.
    • The back of the cover is held in place by two locking tabs. To remove the cover, pull it back slightly and it should come free.
    • You will then want to remove these screws which are the same size.
    • The needle is sharp, so be careful.
  5. Keurig K10 MINI PLUS Top Needle Replacement: 手順 5、 1の画像 1
    • Once you get those removed, you are going to want to pull on the hose until it pops off.
    • Once the hose comes off, the needle will fall out by itself.
    • Be careful when picking up the needle as the needle is sharp.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Mark Henein
メンバー登録日: 02/04/16
369 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 17-6, Blackwell Winter 2016 USF Tampa, Team 17-6, Blackwell Winter 2016人のメンバー
USFT-BLACKWELL-W16S17G6
2 メンバー
2のガイドは作成済み
コメント 1 件
Where do you buy the needle I know you can get the exit needle with the holder, but can’t find this one.
tbushwacker - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 30
今までの合計 5,009
