メインコンテンツにスキップ
Keurig K10 MINI PLUS Handle Replacement
必要な工具と部品
  1. Keurig K10 MINI PLUS Handle Replacement, Top Needle: 手順 1、 2の画像 1 Keurig K10 MINI PLUS Handle Replacement, Top Needle: 手順 1、 2の画像 2
    • Remove two 9 mm Phillips #1 screws.
    • Avoid the top needle if at all possible. The needle may cut you and/or penetrate your skin.
    • The screws are located on the top of where the K-Cup would be.
  2. Keurig K10 MINI PLUS Handle Replacement: 手順 2、 3の画像 1 Keurig K10 MINI PLUS Handle Replacement: 手順 2、 3の画像 2 Keurig K10 MINI PLUS Handle Replacement: 手順 2、 3の画像 3
    • Once you remove the screws, the top cover should come out.
    • The back of the cover is held in place by two locking tabs. To remove the cover, pull it back slightly and it should come free.
    • You will then want to remove these screws which are the same size.
    • The needle is sharp, so be careful.
  3. Keurig K10 MINI PLUS Handle Replacement: 手順 3、 1の画像 1
    • Once you get those removed, you are going to want to pull on the hose until it pops off.
    • Once the hose comes off, the needle will fall out by itself.
    • Be careful when picking up the needle as the needle is sharp.
  4. Keurig K10 MINI PLUS Handle Replacement, Handle: 手順 4、 1の画像 1
    • Remove the two Phillips #1 screws.
    • The top needle is intact and there, so be careful when in this area.
  5. Keurig K10 MINI PLUS Handle Replacement: 手順 5、 2の画像 1 Keurig K10 MINI PLUS Handle Replacement: 手順 5、 2の画像 2
    • Next, after the removal of the hose on the top by simply pulling it off, remove the following four Phillips #1 screws.
  6. Keurig K10 MINI PLUS Handle Replacement: 手順 6、 1の画像 1
    • Once you take off the screws, this part of the handle will come off.
  7. Keurig K10 MINI PLUS Handle Replacement: 手順 7、 1の画像 1
    • To pull this part off, pull inwards with the these tabs located on both sides of the handle assembly.
  8. Keurig K10 MINI PLUS Handle Replacement: 手順 8、 3の画像 1 Keurig K10 MINI PLUS Handle Replacement: 手順 8、 3の画像 2 Keurig K10 MINI PLUS Handle Replacement: 手順 8、 3の画像 3
    • Next, remove these two Phillips #1 screws to allow the release of the actual handle from the frame.
    • For the O rings, we used the plastic prying tools. Just keep in mind that you might want to hold one side of the O ring down while trying to pry off the other side with the other.
    • Once you get the O rings on both sides out, you can pull the handle by pulling on each side.
  9. Keurig K10 MINI PLUS Handle Replacement: 手順 9、 1の画像 1
    • Once you pull both sides, the handle will come off as shown.
終わりに
作成者
3人の作成者と共同で作成されました。
Roberto Maldonado
メンバー登録日: 02/04/16
395 ポイント
1ガイドが承認済み
チーム
iFixit, Team 1-1, Weber Winter 2016 iFixit, Team 1-1, Weber Winter 2016人のメンバー
FIX-WEBER-W16S1G1
4 メンバー
37のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 20
今までの合計 2,343
