はじめに
Clogged filter?
This guide will show you how to remove the water filter found inside the Keurig B70 Platinum water reservoir.
You will only need a Phillips #2 screwdriver for this guide.
必要な工具と部品
Remove the water reservoir from the Keurig by lifting it upwards and pulling it outwards.
Firmly twist the filter counterclockwise to remove it.
Where to get the filter??
4 件のコメント
I bought a Kuerig tall handle starter kit with charcoal filters. Tried install it over the existing built in filter, it didn’t fit. I think the round filter has to be removed in order to use the starter kit.
What is the part number for the K70 reservoir filter?
Raymond Stivenson - 返信
