Turn off and unplug the Keurig before starting.
Lay the Keurig on its back and open the lid.
Using a Phillips #2 screwdriver, remove the two 21.0 mm screws.
Be careful when removing the screws. There is a sharp puncture needle!
You may need to use tweezers to get the screws out.
Using both hands, pull the puncture needle tube and the Keurig tube apart to disconnect the tubes.
Don't be afraid to pull hard! The tubes are tightly connected.
Using a Phillips #2 screwdriver, remove the two 9.0 mm screws next to the detached tube.
Hold on to the puncture needle when removing the screws to ensure that the puncture needle does not fall and cause injury.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
