メインコンテンツにスキップ
はじめに
K-Cup pack holder is stuck?
This guide will show you how to remove and replace the K-Cup Portion Pack Holder for the Keurig B70 Platinum if you're experiencing any problems with the pack holder. Before continuing with the guide, you're going to need a Phillips #2 screwdriver.
パーツ
パーツは指定されていません。
  1. Turn off and unplug the Keurig before starting. Open the lid and remove the two 11.0 mm screws located below the K-Cup holder.
    • Turn off and unplug the Keurig before starting.
    • Open the lid and remove the two 11.0 mm screws located below the K-Cup holder.
  2. Pull the black plastic guard of the K-Cup housing away from the Keurig.
    • Pull the black plastic guard of the K-Cup housing away from the Keurig.
    • Depending on the angle, the guard can actually fall out instead. Be ready to catch it!
  3. Push the black button at the bottom of the lid to remove the K-cup holder assembly. From the top, lift the assembly out of the Keurig. From the top, lift the assembly out of the Keurig.
    • Push the black button at the bottom of the lid to remove the K-cup holder assembly.
    • From the top, lift the assembly out of the Keurig.
  4. Grab the top and the bottom of the holder assembly and pull it apart. Be careful when pulling the assembly. There is a sharp needle!
    • Grab the top and the bottom of the holder assembly and pull it apart.
    • Be careful when pulling the assembly. There is a sharp needle!
    • This step requires a little force.
終わりに
Thu Hoang
メンバー登録日: 2018年10月17日
217 ポイント
2のガイドは作成済み
チーム
UW Tacoma, Team S1-G6, Rose Fall 2018 UW Tacoma, Team S1-G6, Rose Fall 2018人のメンバー
UWT-ROSE-F18S1G6
4 メンバー
5のガイドは作成済み
コメント1件
Spring flew out as I was removing cup holder. Where does it go. How do I reinsert it?
slz2002 - 返信
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 24
今までの合計 630
