はじめに
Is your Keurig slow to brew or leaking water? This quick fix might be your answer to get you right back to brewing. This guide will show you how to easily replace your check valve in the Keurig B70 Platinum. The check valve is located at the top of the machine and can cause slow brewing or water not coming out of your machine if it is clogged or damaged.
Before continuing, make sure you unplug your machine and have a Phillips screwdriver and a pair of scissors handy.
必要な工具と部品
ある他の人がこのガイドを完成しました。
