Turn off and unplug the Keurig before starting.
Turn the Keurig upside down so the metal base is exposed.
Remove the five 12.0 mm screws.
Lift the metal plate off the Keurig and hang it over the side of the device.
Be careful! The metal plate is sharp!
There are wires connected to the metal plate. Make sure the wires are not in the way of the internal components.
Lift the metal base and hover it over the opening of the black plastic base.
Carefully raise the plastic base over the metal base until it is removed.
Make sure to pull the power cord through the base as well!
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
