メインコンテンツにスキップ
Keurig 2.0-400 LCD Screen Replacement
必要な工具と部品
  1. Keurig 2.0-400 LCD Screen Replacement, LCD Screen: 手順 1、 1の画像 1
    • Open the K-Cup Chamber Housing Lid by lifting up the silver handle below the LCD screen.
    • This is the part of the brewer you open to place a K-Cup inside.
  2. Keurig 2.0-400 LCD Screen Replacement: 手順 2、 2の画像 1 Keurig 2.0-400 LCD Screen Replacement: 手順 2、 2の画像 2
    • Place the Keurig on its side.
    • Remove the two 140mm screws located on the underside of the Chamber Lid using the Phillips #1 screwdriver.
    • Remove the top black housing that surrounds the screen.
  3. Keurig 2.0-400 LCD Screen Replacement: 手順 3、 1の画像 1
    • Using the Phillips #1 screwdriver, remove the two 140mm screws connecting the silver handle to the top of the Keurig.
  4. Keurig 2.0-400 LCD Screen Replacement: 手順 4、 1の画像 1
    • Pull out the front silver handle from the top of the brewer.
    • This will further expose the LCD screen.
  5. Keurig 2.0-400 LCD Screen Replacement: 手順 5、 1の画像 1
    • Using the metal spudger, pry open the snaps holding the LCD screen panel to the brewer, just enough for the panel to pop loose.
    • Warning: These snaps are very delicate and can easily be broken. Practice caution as you perform this step.
  6. Keurig 2.0-400 LCD Screen Replacement: 手順 6、 1の画像 1
    • Remove the top black housing by lifting it up.
    • This will expose the frame of the Keurig connecting to the LCD screen.
  7. Keurig 2.0-400 LCD Screen Replacement: 手順 7、 1の画像 1
    • Remove the black latch with the black wire connecting the front end of the panel to the frame.
    • The front end of the panel will now be free.
  8. Keurig 2.0-400 LCD Screen Replacement: 手順 8、 1の画像 1
    • On the bottom of the panel, remove the white tab that connects the wires of the circuit board to the LCD screen
    • To remove the tab, squeeze in on the sides of it as you pull it out.
    • Remove the touch screen panel from your device.
終わりに
5 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Alec Jamosmos
メンバー登録日: 04/22/18
936 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team S24-G8, Maness Spring 2018 Cal Poly, Team S24-G8, Maness Spring 2018人のメンバー
CPSU-MANESS-S18S24G8
4 メンバー
5のガイドは作成済み
4 件のコメント
Hello Alec,
Thank you for providing this repair guide! Could you kindly provide the screen size and where one might be able to purchase one? It would be greatly appreciated.
Regards.
Christopher Rodriguez - 返信
Yes love the demo, now where would one find the screen to replace. Keurig states these are no longer available.
staci werkmeister - 返信
Try eBay. I saw one there.
DEBORAH A YOCHIM - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 23
過去 30 日: 91
今までの合計 15,888
