メインコンテンツにスキップ
Kenwood KDC-BT565U CD Drive Replacement
必要な工具と部品
  1. Kenwood KDC-BT565U CD Drive Replacement, Face Plate: 手順 1、 1の画像 1
    • Press the eject button on the bottom left corner of the face plate.
  2. Kenwood KDC-BT565U CD Drive Replacement: 手順 2、 3の画像 1 Kenwood KDC-BT565U CD Drive Replacement: 手順 2、 3の画像 2 Kenwood KDC-BT565U CD Drive Replacement: 手順 2、 3の画像 3
    • Begin by slightly lifting the face plate out from the side located by the release button.
    • Slide towards the side of the eject button, then completely lift out.
  3. Kenwood KDC-BT565U CD Drive Replacement, Metal Sleeve: 手順 3、 2の画像 1 Kenwood KDC-BT565U CD Drive Replacement, Metal Sleeve: 手順 3、 2の画像 2
    • Grasp the outer metal sleeve with one hand and the front of the unit with the other.
    • Slide the sleeve back until it comes off the unit.
  4. Kenwood KDC-BT565U CD Drive Replacement, CD Drive: 手順 4、 1の画像 1
    • Remove the thin frame from the front of the device. This can be done by first unsnapping the top pegs and then the bottom ones.
  5. Kenwood KDC-BT565U CD Drive Replacement: 手順 5、 3の画像 1 Kenwood KDC-BT565U CD Drive Replacement: 手順 5、 3の画像 2 Kenwood KDC-BT565U CD Drive Replacement: 手順 5、 3の画像 3
    • Lift the clasps of the tabs around the edges by using a plastic opening tool or spudger.
  6. Kenwood KDC-BT565U CD Drive Replacement: 手順 6、 1の画像 1
    • Remove the two 5.5mm Phillips #0 (PH0) screws on the bottom of the unit.
  7. Kenwood KDC-BT565U CD Drive Replacement: 手順 7、 2の画像 1 Kenwood KDC-BT565U CD Drive Replacement: 手順 7、 2の画像 2
    • Remove the two 6mm Phillips #0 screws from the side of the unit.
  8. Kenwood KDC-BT565U CD Drive Replacement: 手順 8、 1の画像 1
    • Remove the 7.5mm Phillips #0 screw in between the red and white RCA inputs.
    • Remove the two 13.5mm Phillips #0 screws towards the top of the aluminum block.
    • Remove the 10mm Phillips #0 screw towards the bottom of the aluminum block.
    • Remove the two 6mm Phillips #0 screws found above the microphone mount and below the circular port.
    • Remove the 7.5mm Phillips #0 screw next to the large rectangular power connector.
    • Remove the 10mm Phillips #0 screw that resides above the aluminum block.
  9. Kenwood KDC-BT565U CD Drive Replacement: 手順 9、 1の画像 1
    • Separate the top and bottom metal housings of the unit carefully.
    • There is a connecting ribbon that links the two halves. Too much force could rip and irreversibly damage the ribbon.
  10. Kenwood KDC-BT565U CD Drive Replacement: 手順 10、 2の画像 1 Kenwood KDC-BT565U CD Drive Replacement: 手順 10、 2の画像 2
    • Carefully pull the ribbon out of the connector found on the bottom half of the unit (the bottom half has the CD drive).
    • To remove the ribbon, grip the black base connector with one hand and the base of the ribbon with the other. The ribbon will have a blue, reinforced section close to the base (seen in second picture) which makes it easier to pull.
  11. Kenwood KDC-BT565U CD Drive Replacement: 手順 11、 3の画像 1 Kenwood KDC-BT565U CD Drive Replacement: 手順 11、 3の画像 2 Kenwood KDC-BT565U CD Drive Replacement: 手順 11、 3の画像 3
    • To fully unmount and replace the CD drive, remove the three 6mm Phllips #0 screws that hold the drive to the housing.
終わりに
To reassemble your device, follow these instructions in reverse order. Be careful when reattaching the new CD drive's ribbon to the motherboard. The ribbon can be bent easily.
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Connor Finley
メンバー登録日: 02/18/17
857 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team S2-G5, Lacy Spring 2017 USF Tampa, Team S2-G5, Lacy Spring 2017人のメンバー
USFT-LACY-S17S2G5
4 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 12
今までの合計 531
