メインコンテンツにスキップ
Kenwood KD-37R Turntable Belt Replacement and Modification
必要な工具と部品
  1. Kenwood KD-37R Turntable Belt Replacement and Modification, Turntable Belt: 手順 1、 1の画像 1
    • Always dust your turntable before performing any maintenance or repairs.
  2. Kenwood KD-37R Turntable Belt Replacement and Modification: 手順 2、 1の画像 1
    • Remove the rubber mat from the platter and set it aside in a clean, dust free area.
  3. Kenwood KD-37R Turntable Belt Replacement and Modification: 手順 3、 1の画像 1
    • Remove the metal platter by placing your thumb on the center spindle and two to three fingers in one of the holes.
    • Pull the platter up firmly, but carefully.
  4. Kenwood KD-37R Turntable Belt Replacement and Modification: 手順 4、 1の画像 1
    • Remove the old belt.
    • Throw the old belt away if it's damaged.
  5. Kenwood KD-37R Turntable Belt Replacement and Modification: 手順 5、 1の画像 1
    • Turn the metal platter over.
    • Place the new belt around the inner lip of the metal platter, ensuring there are no twists.
  6. Kenwood KD-37R Turntable Belt Replacement and Modification: 手順 6、 2の画像 1 Kenwood KD-37R Turntable Belt Replacement and Modification: 手順 6、 2の画像 2
    • Put the metal platter back on the turn table.
    • Use your thumb and forefinger to pull a small section of the belt behind the pulley shaft.
  7. Kenwood KD-37R Turntable Belt Replacement and Modification: 手順 7、 1の画像 1
    • Replace the rubber mat.
    • Play a record to test the new belt.
    • This is when I discovered the belt that was sent to me was slightly too big. Not to fear! We can fix that.
  8. Kenwood KD-37R Turntable Belt Replacement and Modification: 手順 8、 3の画像 1 Kenwood KD-37R Turntable Belt Replacement and Modification: 手順 8、 3の画像 2 Kenwood KD-37R Turntable Belt Replacement and Modification: 手順 8、 3の画像 3
    • Remove the rubber mat.
    • Before removing the metal platter, carefully remove the belt from behind the pulley shaft.
    • Remove the metal platter and the belt.
  9. Kenwood KD-37R Turntable Belt Replacement and Modification: 手順 9、 2の画像 1 Kenwood KD-37R Turntable Belt Replacement and Modification: 手順 9、 2の画像 2
    • Bring two cups of water to a full boil.
  10. Kenwood KD-37R Turntable Belt Replacement and Modification: 手順 10、 3の画像 1 Kenwood KD-37R Turntable Belt Replacement and Modification: 手順 10、 3の画像 2 Kenwood KD-37R Turntable Belt Replacement and Modification: 手順 10、 3の画像 3
    • Turn off heat.
    • Using tongs, fully submerge the belt into the water.
    • Be careful, the water should be very hot for this to work, and can burn your skin.
    • Let the belt sit in the water for between 6-8 minutes.
  11. Kenwood KD-37R Turntable Belt Replacement and Modification: 手順 11、 2の画像 1 Kenwood KD-37R Turntable Belt Replacement and Modification: 手順 11、 2の画像 2
    • Using tongs, remove the belt from the water and let it dry completely.
    • The water may still be very hot.
  12. Kenwood KD-37R Turntable Belt Replacement and Modification: 手順 12、 1の画像 1
    • Repeat steps 5, 6, and 7, and enjoy the music!
ゴール
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Tim
メンバー登録日: 09/27/23
229 ポイント
1ガイドが承認済み
チーム
University of Arizona, Team 6-3, Cools Stephens Fall 2023 University of Arizona, Team 6-3, Cools Stephens Fall 2023人のメンバー
ARIZONA-COOLS STEPHENS-F23S6G3
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 36
今までの合計 163
