メインコンテンツにスキップ
Kenwood DRV-N520 Dashcam Speaker Replacement
必要な工具と部品
  1. Kenwood DRV-N520 Dashcam Speaker Replacement, Speaker: 手順 1、 3の画像 1 Kenwood DRV-N520 Dashcam Speaker Replacement, Speaker: 手順 1、 3の画像 2 Kenwood DRV-N520 Dashcam Speaker Replacement, Speaker: 手順 1、 3の画像 3
    • Use a Phillips #0 screwdriver to remove the four 3mm screws from the device backing.
    • Remove the backing.
  2. Kenwood DRV-N520 Dashcam Speaker Replacement: 手順 2、 3の画像 1 Kenwood DRV-N520 Dashcam Speaker Replacement: 手順 2、 3の画像 2 Kenwood DRV-N520 Dashcam Speaker Replacement: 手順 2、 3の画像 3
    • Use a Phillips #0 screwdriver to remove the four 3mm screws in the copper plate.
    • Remove the copper plate from the housing. The motherboard and capacitors should now be visible.
  3. Kenwood DRV-N520 Dashcam Speaker Replacement: 手順 3、 2の画像 1 Kenwood DRV-N520 Dashcam Speaker Replacement: 手順 3、 2の画像 2
    • Use the screwdriver to remove the two screws holding the motherboard in place.
    • Before attempting to remove the board, disconnect the camera by removing the ribbon cable from its corresponding connection on the board.
    • To remove the ribbon cable, use a plastic spudger to gently apply pressure to the lever that secures the cable in place while simultaneously applying a light pulling pressure on the ribbon cable.
    • Disconnect the speaker connections (red and black wires) from the motherboard by applying pressure to the clip on its corresponding socket.
    • Once all connections have been severed, gently remove the motherboard from the device casing.
    • The speaker unit and corresponding mounting hardware should now be visible.
  4. Kenwood DRV-N520 Dashcam Speaker Replacement: 手順 4、 2の画像 1 Kenwood DRV-N520 Dashcam Speaker Replacement: 手順 4、 2の画像 2
    • Use your Phillips #0 screwdriver to remove the two 3mm screws from the speaker's mounting bracket.
    • Remove the speaker from the device.
終わりに
To re-assemble your device, follow these steps in reverse order.
作成者
5人の作成者と共同で作成されました。
NathanGoodwin
メンバー登録日: 01/30/20
136 ポイント
1ガイドが承認済み
チーム
ERAU-LAMOTHE-S20S14G1 ERAU-LAMOTHE-S20S14G1人のメンバー
Local Repair Groups
4 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 183
