メインコンテンツにスキップ
Kenwood DNX571HD Satellite Antenna Connection Replacement
必要な工具と部品
  1. Kenwood DNX571HD Satellite Antenna Connection Replacement, CD/DVD Drive: 手順 1、 2の画像 1 Kenwood DNX571HD Satellite Antenna Connection Replacement, CD/DVD Drive: 手順 1、 2の画像 2
    • Unscrew the four 3.5mm side screws with a Phillips #1 screwdriver.
    • There are two screws per side.
  2. Kenwood DNX571HD Satellite Antenna Connection Replacement: 手順 2、 3の画像 1 Kenwood DNX571HD Satellite Antenna Connection Replacement: 手順 2、 3の画像 2 Kenwood DNX571HD Satellite Antenna Connection Replacement: 手順 2、 3の画像 3
    • Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top.
    • Place the spudger between the plastic tab and the metal case and gently lift the spudger away from the case.
  3. Kenwood DNX571HD Satellite Antenna Connection Replacement: 手順 3、 1の画像 1
    • Pull the top of the front panel out and down to remove front panel.
    • Remove the front panel gently so as not to damage the ribbon cables behind it.
  4. Kenwood DNX571HD Satellite Antenna Connection Replacement: 手順 4、 3の画像 1 Kenwood DNX571HD Satellite Antenna Connection Replacement: 手順 4、 3の画像 2 Kenwood DNX571HD Satellite Antenna Connection Replacement: 手順 4、 3の画像 3
    • Unscrew the three 5mm screws from the top of the device using a Phillips #1 screwdriver.
    • Lift up to remove the top casing.
  5. Kenwood DNX571HD Satellite Antenna Connection Replacement: 手順 5、 1の画像 1
    • Lift the CD drive carefully to expose the attached cable underneath.
  6. Kenwood DNX571HD Satellite Antenna Connection Replacement: 手順 6、 2の画像 1 Kenwood DNX571HD Satellite Antenna Connection Replacement: 手順 6、 2の画像 2
    • Flip up the black clasp with a spudger to disconnect the large white ribbon cable connecting the CD drive to the board underneath.
  7. Kenwood DNX571HD Satellite Antenna Connection Replacement, Cooling Fan: 手順 7、 1の画像 1
    • Carefully unplug the fan power cord with the tweezers.
  8. Kenwood DNX571HD Satellite Antenna Connection Replacement: 手順 8、 2の画像 1 Kenwood DNX571HD Satellite Antenna Connection Replacement: 手順 8、 2の画像 2
    • Unscrew the three 5mm length screws with the Phillips #1 screwdriver.
    • Remove the metal plate
    • Removing the plate will damage the heat sink compound. This will need to be replaced during reassembly.
  9. Kenwood DNX571HD Satellite Antenna Connection Replacement: 手順 9、 2の画像 1 Kenwood DNX571HD Satellite Antenna Connection Replacement: 手順 9、 2の画像 2
    • Unscrew the three 5.5mm long screws with a Phillips #1 screwdriver.
  10. Kenwood DNX571HD Satellite Antenna Connection Replacement: 手順 10、 3の画像 1 Kenwood DNX571HD Satellite Antenna Connection Replacement: 手順 10、 3の画像 2 Kenwood DNX571HD Satellite Antenna Connection Replacement: 手順 10、 3の画像 3
    • Remove the four 5.5mm screws with the Phillips #1 screwdriver.
  11. Kenwood DNX571HD Satellite Antenna Connection Replacement: 手順 11、 1の画像 1
    • Lift the top part of the unit up from the lower chassis.
  12. Kenwood DNX571HD Satellite Antenna Connection Replacement: 手順 12、 2の画像 1 Kenwood DNX571HD Satellite Antenna Connection Replacement: 手順 12、 2の画像 2
    • Remove the two 13mm long screws with a Phillips #1 screwdriver.
    • Gently thread the power cable through the circuit boards to separate the fan from the body of the stereo.
  13. Kenwood DNX571HD Satellite Antenna Connection Replacement, Satellite Antenna Connection: 手順 13、 2の画像 1 Kenwood DNX571HD Satellite Antenna Connection Replacement, Satellite Antenna Connection: 手順 13、 2の画像 2
    • Remove the four 5mm screws from the corners of the circuit board using a Phillips #1 screwdriver
    • Lift the circuit board from the rest of the assembly.
  14. Kenwood DNX571HD Satellite Antenna Connection Replacement: 手順 14、 1の画像 1
    • Desolder the 12 leads to remove the connector from the circuit board.
    • There are ten leads in two parallel rows and two larger leads below them.
    • The satellite antenna is a thru-hole-mounted device. You must apply heat to each soldered pin individually and pull them out of the holes while the solder is molten.
    • The solder material, pins, and any surrounding material will get VERY hot while melting the connections. Do not touch any metal parts during the desoldering process and give the device time to cool off once you’re finished. It may also be good to take breaks so that the electronics aren’t kept hot for extended periods of time.
終わりに
作成者
5人の作成者と共同で作成されました。
Wendy Zaballos
メンバー登録日: 09/17/18
952 ポイント
6のガイドは作成済み
チーム
Washington State, Team S1-G1, Hope Fall 2018 Washington State, Team S1-G1, Hope Fall 2018人のメンバー
WSU-HOPE-F18S1G1
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 621
