Turn off the stereo and remove from the vehicle before starting.
Unscrew the four 3.5mm side screws with a Phillips #1 screwdriver.
There are two screws per side.
Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top.
Place the spudger between the plastic tab and the metal case and gently lift the spudger away from the case.
この手順で使用する道具:
購入する
Unscrew the four 5.5mm screws with a JIS #00 screwdriver.
Unscrew the 4mm screw with a Phillips #1 screwdriver.
Remove the disconnected circuit board.
Unscrew the four 4mm screws on the main board with a Phillips #1 screwdriver.
Gently lift the board out of the casing.
Unscrew the 5.5mm screw on the metal plate with a JIS #00 screwdriver.
Use the spudger to unhook the metal tabs and detach the metal plate from the plastic housing.
Place the spudger between the metal tab and the plastic case and gently lift the spudger away from the case.
Gently press the front of the screen to detach it from the plastic housing.
When removing the screen, gently flex out the plastic housing to help get the display past the plastic latch.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
