メインコンテンツにスキップ
Kenwood DNX571HD LCD Touch Screen Replacement
必要な工具と部品
  1. Kenwood DNX571HD LCD Touch Screen Replacement, LCD Touch Screen: 手順 1、 2の画像 1 Kenwood DNX571HD LCD Touch Screen Replacement, LCD Touch Screen: 手順 1、 2の画像 2
    • Turn off the stereo and remove from the vehicle before starting.
    • Unscrew the four 3.5mm side screws with a Phillips #1 screwdriver.
    • There are two screws per side.
  2. Kenwood DNX571HD LCD Touch Screen Replacement: 手順 2、 3の画像 1 Kenwood DNX571HD LCD Touch Screen Replacement: 手順 2、 3の画像 2 Kenwood DNX571HD LCD Touch Screen Replacement: 手順 2、 3の画像 3
    • Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top.
    • Place the spudger between the plastic tab and the metal case and gently lift the spudger away from the case.
  3. Kenwood DNX571HD LCD Touch Screen Replacement: 手順 3、 1の画像 1
    • Pull the top of the front panel out and down to remove front panel.
    • Remove the front panel gently so as not to damage the ribbon cables behind it.
  4. Kenwood DNX571HD LCD Touch Screen Replacement: 手順 4、 2の画像 1 Kenwood DNX571HD LCD Touch Screen Replacement: 手順 4、 2の画像 2
    • Flip up the black clasp with the spudger to disconnect the small white ribbon cable from the main board.
  5. Kenwood DNX571HD LCD Touch Screen Replacement: 手順 5、 2の画像 1 Kenwood DNX571HD LCD Touch Screen Replacement: 手順 5、 2の画像 2
    • Flip up the black clasp with the spudger to disconnect the large white ribbon cable from the main board.
  6. Kenwood DNX571HD LCD Touch Screen Replacement: 手順 6、 2の画像 1 Kenwood DNX571HD LCD Touch Screen Replacement: 手順 6、 2の画像 2
    • Flip up the black clasp with the spudger to disconnect the small white ribbon cable from the vertical board.
    • Carefully pull the ribbon from the clasp with the spudger.
  7. Kenwood DNX571HD LCD Touch Screen Replacement: 手順 7、 2の画像 1 Kenwood DNX571HD LCD Touch Screen Replacement: 手順 7、 2の画像 2
    • Flip up the black clasp with the spudger to disconnect the large orange ribbon cable from the main board.
  8. Kenwood DNX571HD LCD Touch Screen Replacement: 手順 8、 2の画像 1 Kenwood DNX571HD LCD Touch Screen Replacement: 手順 8、 2の画像 2
    • Push out the black clasp with the spudger to disconnect the small orange ribbon cable from the main board.
    • Gently push the ribbon out of the clasp with the spudger.
  9. Kenwood DNX571HD LCD Touch Screen Replacement: 手順 9、 2の画像 1 Kenwood DNX571HD LCD Touch Screen Replacement: 手順 9、 2の画像 2
    • Using a pair of tweezers, gently pull up on the connector for the power cable to disconnect it from the main board.
  10. Kenwood DNX571HD LCD Touch Screen Replacement: 手順 10、 2の画像 1 Kenwood DNX571HD LCD Touch Screen Replacement: 手順 10、 2の画像 2
    • Unscrew the two 4mm screws holding down the board that is standing vertically with a Phillips #1 screwdriver.
    • Pull up on the board to remove it.
  11. Kenwood DNX571HD LCD Touch Screen Replacement: 手順 11、 2の画像 1 Kenwood DNX571HD LCD Touch Screen Replacement: 手順 11、 2の画像 2
    • Unscrew the four 5.5mm screws with a JIS #00 screwdriver.
    • Unscrew the 4mm screw with a Phillips #1 screwdriver.
    • Remove the disconnected circuit board.
  12. Kenwood DNX571HD LCD Touch Screen Replacement: 手順 12、 2の画像 1 Kenwood DNX571HD LCD Touch Screen Replacement: 手順 12、 2の画像 2
    • Unscrew the four 4mm screws on the main board with a Phillips #1 screwdriver.
    • Gently lift the board out of the casing.
    • Unscrew the 5.5mm screw on the metal plate with a JIS #00 screwdriver.
  13. Kenwood DNX571HD LCD Touch Screen Replacement: 手順 13、 1の画像 1
    • Carefully remove the tape attaching the power cable to the metal plate.
  14. Kenwood DNX571HD LCD Touch Screen Replacement: 手順 14、 2の画像 1 Kenwood DNX571HD LCD Touch Screen Replacement: 手順 14、 2の画像 2
    • Use the spudger to unhook the metal tabs and detach the metal plate from the plastic housing.
    • Place the spudger between the metal tab and the plastic case and gently lift the spudger away from the case.
  15. Kenwood DNX571HD LCD Touch Screen Replacement: 手順 15、 2の画像 1 Kenwood DNX571HD LCD Touch Screen Replacement: 手順 15、 2の画像 2
    • Gently press the front of the screen to detach it from the plastic housing.
    • When removing the screen, gently flex out the plastic housing to help get the display past the plastic latch.
終わりに
4 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Wendy Zaballos
メンバー登録日: 09/17/18
952 ポイント
6のガイドは作成済み
チーム
Washington State, Team S1-G1, Hope Fall 2018 Washington State, Team S1-G1, Hope Fall 2018人のメンバー
WSU-HOPE-F18S1G1
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 20
過去 30 日: 73
今までの合計 9,210
