メインコンテンツにスキップ
Kenwood DNX571HD Cooling Fan Replacement
必要な工具と部品
  1. Kenwood DNX571HD Cooling Fan Replacement, CD/DVD Drive: 手順 1、 2の画像 1 Kenwood DNX571HD Cooling Fan Replacement, CD/DVD Drive: 手順 1、 2の画像 2
    • Unscrew the four 3.5mm side screws with a Phillips #1 screwdriver.
    • There are two screws per side.
  2. Kenwood DNX571HD Cooling Fan Replacement: 手順 2、 3の画像 1 Kenwood DNX571HD Cooling Fan Replacement: 手順 2、 3の画像 2 Kenwood DNX571HD Cooling Fan Replacement: 手順 2、 3の画像 3
    • Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top.
    • Place the spudger between the plastic tab and the metal case and gently lift the spudger away from the case.
  3. Kenwood DNX571HD Cooling Fan Replacement: 手順 3、 1の画像 1
    • Pull the top of the front panel out and down to remove front panel.
    • Remove the front panel gently so as not to damage the ribbon cables behind it.
  4. Kenwood DNX571HD Cooling Fan Replacement: 手順 4、 3の画像 1 Kenwood DNX571HD Cooling Fan Replacement: 手順 4、 3の画像 2 Kenwood DNX571HD Cooling Fan Replacement: 手順 4、 3の画像 3
    • Unscrew the three 5mm screws from the top of the device using a Phillips #1 screwdriver.
    • Lift up to remove the top casing.
  5. Kenwood DNX571HD Cooling Fan Replacement: 手順 5、 1の画像 1
    • Lift the CD drive carefully to expose the attached cable underneath.
  6. Kenwood DNX571HD Cooling Fan Replacement: 手順 6、 2の画像 1 Kenwood DNX571HD Cooling Fan Replacement: 手順 6、 2の画像 2
    • Flip up the black clasp with a spudger to disconnect the large white ribbon cable connecting the CD drive to the board underneath.
  7. Kenwood DNX571HD Cooling Fan Replacement, Cooling Fan: 手順 7、 1の画像 1
    この手順で使用する道具:
    購入する
    • Carefully unplug the fan power cord with the tweezers.
  8. Kenwood DNX571HD Cooling Fan Replacement: 手順 8、 2の画像 1 Kenwood DNX571HD Cooling Fan Replacement: 手順 8、 2の画像 2
    • Unscrew the three 5mm length screws with the Phillips #1 screwdriver.
    • Remove the metal plate
    • Removing the plate will damage the heat sink compound. This will need to be replaced during reassembly.
  9. Kenwood DNX571HD Cooling Fan Replacement: 手順 9、 2の画像 1 Kenwood DNX571HD Cooling Fan Replacement: 手順 9、 2の画像 2
    • Unscrew the three 5.5mm long screws with a Phillips #1 screwdriver.
  10. Kenwood DNX571HD Cooling Fan Replacement: 手順 10、 3の画像 1 Kenwood DNX571HD Cooling Fan Replacement: 手順 10、 3の画像 2 Kenwood DNX571HD Cooling Fan Replacement: 手順 10、 3の画像 3
    • Remove the four 5.5mm screws with the Phillips #1 screwdriver.
  11. Kenwood DNX571HD Cooling Fan Replacement: 手順 11、 1の画像 1
    • Lift the top part of the unit up from the lower chassis.
  12. Kenwood DNX571HD Cooling Fan Replacement: 手順 12、 2の画像 1 Kenwood DNX571HD Cooling Fan Replacement: 手順 12、 2の画像 2
    • Remove the two 13mm long screws with a Phillips #1 screwdriver.
    • Gently thread the power cable through the circuit boards to separate the fan from the body of the stereo.
終わりに
作成者
3人の作成者と共同で作成されました。
Wendy Zaballos
メンバー登録日: 09/17/18
952 ポイント
6のガイドは作成済み
チーム
Washington State, Team S1-G1, Hope Fall 2018 Washington State, Team S1-G1, Hope Fall 2018人のメンバー
WSU-HOPE-F18S1G1
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 15
今までの合計 911
