必要な工具と部品
Turn the mixer upside down
Remove the two screws holding the white cable grip.
Remove the black cable grip. The long screw also holds the cover onto the terminal block
Remove the cable cover to expose the terminal block.
Remove the wires from the live and neutral terminals.
Thread the cables out though the cover and then from the mixer chassis
To refit simply follow the removal process in reverse
Be sure to connect the wires to the correct terminals, Brown - Live, Blue, Neutral.
If fitting a new plug ensure it is fitted with the appropriate fuse. If in any doubt consult a compitent electrician/electrical engineer
4 の人々がこのガイドを完成させました。
コメント 1 件
Important addition: make sure you leave enough cable length free under the mixer for when you raise the top of the mixer during use to change accessories or remove the bowl. Our local electrical repair shop didn’t think to do this and as soon as I raised the top the cable was pulled out.
My ‘black cable grip’ was a thin orange thing which broke when I removed it. Any suggestions about what I could use to make another please? I tried a strip of vinyl flooring but the screw cut into it.
Picasso - 返信
Try a cable grip, e.g. from Amazon.
VauWeh -
