メインコンテンツにスキップ
Kenwood Chef A701A Power Cable Replacement
必要な工具と部品
  1. Kenwood Chef A701A Power Cable Replacement, Remove Cable Grips: 手順 1、 2の画像 1 Kenwood Chef A701A Power Cable Replacement, Remove Cable Grips: 手順 1、 2の画像 2
    • Turn the mixer upside down
    • Remove the two screws holding the white cable grip.
    • Remove the black cable grip. The long screw also holds the cover onto the terminal block
  2. Kenwood Chef A701A Power Cable Replacement, Remove the old cable: 手順 2、 1の画像 1
    • Remove the cable cover to expose the terminal block.
    • Remove the wires from the live and neutral terminals.
    • Thread the cables out though the cover and then from the mixer chassis
    • To refit simply follow the removal process in reverse
    • Be sure to connect the wires to the correct terminals, Brown - Live, Blue, Neutral.
    • If fitting a new plug ensure it is fitted with the appropriate fuse. If in any doubt consult a compitent electrician/electrical engineer
終わりに
3 の人々がこのガイドを完成させました。
Grant
メンバー登録日: 09/29/15
113 ポイント
1ガイドが承認済み
コメント 1 件
Important addition: make sure you leave enough cable length free under the mixer for when you raise the top of the mixer during use to change accessories or remove the bowl. Our local electrical repair shop didn’t think to do this and as soon as I raised the top the cable was pulled out.
Karen Leach - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 60
今までの合計 8,443
