メインコンテンツにスキップ
Kensington Slimblade Trackball Disassembly
必要な工具と部品
  1. Kensington Slimblade Trackball Disassembly, Uncover and Remove the Screws: 手順 1、 3の画像 1 Kensington Slimblade Trackball Disassembly, Uncover and Remove the Screws: 手順 1、 3の画像 2 Kensington Slimblade Trackball Disassembly, Uncover and Remove the Screws: 手順 1、 3の画像 3
    • Remove the ball and flip the base over.
    • Take off the rubber feet hiding 4 Phillips (PH1) screws using a spudger.
    • Remove the rubber crown hiding 3 small Phillips (PH0) screws.
    • Remove the seven screws.
  2. Kensington Slimblade Trackball Disassembly, Opening the Case: 手順 2、 3の画像 1 Kensington Slimblade Trackball Disassembly, Opening the Case: 手順 2、 3の画像 2 Kensington Slimblade Trackball Disassembly, Opening the Case: 手順 2、 3の画像 3
    • Using an opening pick, pry up the lower case from the bottom.
    • Tilt the lower case to the left to access the USB cable that is routed through a channel in the lower case.
    • Loosen the cable retainer to free the lower housing.
  3. Kensington Slimblade Trackball Disassembly, Remove the Circuit Board: 手順 3、 3の画像 1 Kensington Slimblade Trackball Disassembly, Remove the Circuit Board: 手順 3、 3の画像 2 Kensington Slimblade Trackball Disassembly, Remove the Circuit Board: 手順 3、 3の画像 3
    • Flip up the retaining lever of the ZIF connector on the horizontal optical sensor.
    • Remove the cable from the connector.
    • Flip up the retaining lever of the ZIF connector on the vertical optical sensor.
    • Remove the 3 Phillips PH0 screws securing the circuit board. They are marked with white circles.
    • Remove the circuit board by carefully lifting with a spudger. Place it on a stable support to dust off the micro contacts.
  4. Kensington Slimblade Trackball Disassembly, Dust the Circuit Board: 手順 4、 3の画像 1 Kensington Slimblade Trackball Disassembly, Dust the Circuit Board: 手順 4、 3の画像 2 Kensington Slimblade Trackball Disassembly, Dust the Circuit Board: 手順 4、 3の画像 3
    • Dust the button contacts by pressing on them with a spudger and blowing into them with a hand blower. Repeat ten to twenty times for each of the four contacts.
    • Remove the screws from the horizontal displacement sensor.
    • Dust the sensor as needed. (This one is surprisingly clean.)
    • Do the same for the vertical displacement sensor.
終わりに
To reassemble your device, follow the instructions in reverse order.
ある他の人がこのガイドを完成しました。
以下の翻訳者の皆さんにお礼を申し上げます:
fr en
100%
Jerry Wheelerさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
作成者
1人の作成者と共同作成されました。
Ludovic
メンバー登録日: 09/18/17
686 ポイント
4のガイドは作成済み
チーム
Francophones Francophones人のメンバー
Community
25 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 17
過去 30 日: 70
今までの合計 542
