メインコンテンツにスキップ
はじめに
Learn how to properly remove the dustbin filter on your Kenmore 78423.
ツール
ツールは指定されていません。
パーツ
パーツは指定されていません。
  1. Grab the dustbin handle, press and hold the button at the top of the handle. Pull the dustbin up and away from the main body.
    • Grab the dustbin handle, press and hold the button at the top of the handle.
    • Pull the dustbin up and away from the main body.
  2. Press the button located beneath the circular opening on the dust bin; this will open the bottom of the dustbin. Properly dispose any contents of the dust bin into a wastebasket.
    • Press the button located beneath the circular opening on the dust bin; this will open the bottom of the dustbin.
    • Properly dispose any contents of the dust bin into a wastebasket.
  3. MacBook Battery 修理キット
    最低価格 $69.99
    Buy Now
    最低価格 $69.99
    Buy Now
  4. Pinch and grasp the raised handle on the primary dustbin filter. Lift the primary dustbin filter up and away from the dustbin and place it to the side. Lift the primary dustbin filter up and away from the dustbin and place it to the side.
    • Pinch and grasp the raised handle on the primary dustbin filter.
    • Lift the primary dustbin filter up and away from the dustbin and place it to the side.
  5. Grasp the foam filter and lift up to remove. The foam filter may be lodged inside of the primary dustbin filter. In this case, both filters may be removed at the same time.
    • Grasp the foam filter and lift up to remove.
    • The foam filter may be lodged inside of the primary dustbin filter. In this case, both filters may be removed at the same time.
まとめ
ある他の人がこのガイドを完成しました。
Christopher Bradley
メンバー登録日: 2018年09月17日
612 ポイント
5のガイドは作成済み
チーム
CSU Fullerton, Team S2-G4, Bruce Fall 2018 CSU Fullerton, Team S2-G4, Bruce Fall 2018人のメンバー
CSUF-BRUCE-F18S2G4
4 メンバー
5のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 137
