メインコンテンツにスキップ
Kenmore 110 Series Washing Machine Water Level Sensor Replacement
必要な工具と部品
  1. Kenmore 110 Series Washing Machine Water Level Sensor Replacement, Water Level Sensor: 手順 1、 1の画像 1
    • Unplug the washing machine!
    • Using a 5/16" socket wrench or an adjustable wrench, remove the three screws from the top rear of the washer.
    • Lifting from the rear, remove the top panel.
    • The top panel will still be connected by wires and hoses. It will help if you have a flat raised surface to set the top panel on.
  2. Kenmore 110 Series Washing Machine Water Level Sensor Replacement: 手順 2、 3の画像 1 Kenmore 110 Series Washing Machine Water Level Sensor Replacement: 手順 2、 3の画像 2 Kenmore 110 Series Washing Machine Water Level Sensor Replacement: 手順 2、 3の画像 3
    • Using a 5/16" socket wrench or a hand wrench, remove the two screws from the component cover.
    • From the bottom, pull out and remove the component cover.
  3. Kenmore 110 Series Washing Machine Water Level Sensor Replacement: 手順 3、 3の画像 1 Kenmore 110 Series Washing Machine Water Level Sensor Replacement: 手順 3、 3の画像 2 Kenmore 110 Series Washing Machine Water Level Sensor Replacement: 手順 3、 3の画像 3
    • Remove wires from water level sensor.
    • With a Phillips screwdriver remove the mounting screw.
    • Cut the zip tie and remove water level hose.
終わりに
5 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Robert Trout
メンバー登録日: 09/26/12
1,234 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 15-43, Forte Fall 2012 Cal Poly, Team 15-43, Forte Fall 2012人のメンバー
CPSU-FORTE-F12S15G43
5 メンバー
11のガイドは作成済み
4 件のコメント
how to test water level switch??
countryrhoads4x4 - 返信
What is the water sensor part # for a Kenmore model #11029842990?
Who has that part 4the best price?
Rod Brannon - 返信
Hi,
I replaced the water-level pressure switch with a new kit but it did not resolve my problem. After installing the switch and line, I selected the lowest level but the tub continued to fill beyond the smallest wash level. I have a Kenmore Model # 110.20902. What other part or solution could resolve my issue?
BTW: I read replacing the water inlet valve night be involved but I already did that within the last six months and everything worked fine until I noticed the water level had changed the last two washes to a large load only. In fact, the water looked above the large level during my last wash.
I would appreciate any insight.
Shannon
Shannon - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 47
過去 30 日: 144
今までの合計 39,795
