メインコンテンツにスキップ
Kenmore 110 Series Washing Machine Lid Switch Replacement
必要な工具と部品
  1. Kenmore 110 Series Washing Machine Lid Switch Replacement, Lid Switch: 手順 1、 1の画像 1
    • To avoid risk of electric shock, unplug the washing machine.
    • Using a 5/16" socket wrench or an adjustable wrench, remove the three screws from the top rear of the washer.
    • Lifting from the rear, remove the top panel.
    • Set the top panel on its rear face, with its underside facing you.
    • The top panel will still be connected to the washer by wires and hoses. It will help if you have a flat raised surface to set the top panel on.
  2. Kenmore 110 Series Washing Machine Lid Switch Replacement: 手順 2、 2の画像 1 Kenmore 110 Series Washing Machine Lid Switch Replacement: 手順 2、 2の画像 2
    • Using a 5/16" socket wrench or hand wrench, remove the two screws from the component cover.
    • Gripping from the bottom, pull the component cover out of the washer.
  3. Kenmore 110 Series Washing Machine Lid Switch Replacement: 手順 3、 3の画像 1 Kenmore 110 Series Washing Machine Lid Switch Replacement: 手順 3、 3の画像 2 Kenmore 110 Series Washing Machine Lid Switch Replacement: 手順 3、 3の画像 3
    • Carefully unplug the two wires connected to the lid switch.
    • Remove the two Phillips screws securing the bracket.
    • Remove the green ground wire.
    • With a screwdriver, remove the single screw connecting the lid switch to the bracket.
終わりに
9 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Robert Trout
メンバー登録日: 09/26/12
1,234 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 15-43, Forte Fall 2012 Cal Poly, Team 15-43, Forte Fall 2012人のメンバー
CPSU-FORTE-F12S15G43
5 メンバー
12のガイドは作成済み
16件のガイドコメント
My Kenmore Model 110.24622300 does NOT look anything like this!
rlhaan36 - 返信
my model # 11088732796 is not the same as yours
glafleur1 -
No it ia neither of those. Thank for the reply though. My washer is a 90 series.
Jenn Leffring -
Lol I found the solution on YouTube. All it takes is a zip tie because the lid switch for he 90s series Kenmore washer is two half pieces glued together
Jenn Leffring - 返信
my Kenmore washer model# is 110.24812200; series CP2654205. Cannot remove top to repair lid switch following your video! removed the three screwsf from the back but cannot get control panal to come off! Please reply soon.
bill wardle - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 36
過去 30 日: 178
今までの合計 98,805
