メインコンテンツにスキップ
Kemove Snowfox 61 Key Switch Replacement
必要な工具と部品
  1. Kemove Snowfox 61 Key Switch Replacement, Key Switch: 手順 1、 3の画像 1 Kemove Snowfox 61 Key Switch Replacement, Key Switch: 手順 1、 3の画像 2 Kemove Snowfox 61 Key Switch Replacement, Key Switch: 手順 1、 3の画像 3
    • Do not disassemble the keyboard if the keyboard is connected to a power source.
    • Unplug the power cable from the keyboard.
  2. Kemove Snowfox 61 Key Switch Replacement: 手順 2、 3の画像 1 Kemove Snowfox 61 Key Switch Replacement: 手順 2、 3の画像 2 Kemove Snowfox 61 Key Switch Replacement: 手順 2、 3の画像 3
    • Do not pull the keycap other than straight up.
    • Position the keycap puller directly above the keycap.
    • Push the keycap puller down until the two handles are underneath the keycap.
    • Remove all keys.
    • It may be easier to pull by rotating the puller at a 45-degree angle.
  3. Kemove Snowfox 61 Key Switch Replacement: 手順 3、 3の画像 1 Kemove Snowfox 61 Key Switch Replacement: 手順 3、 3の画像 2 Kemove Snowfox 61 Key Switch Replacement: 手順 3、 3の画像 3
    • Fill the plastic container with water.
    • Add 2-3 drops of dish soap.
    • Put the keycaps in.
    • Let the keycaps soak for about 20-30 minutes.
  4. Kemove Snowfox 61 Key Switch Replacement: 手順 4、 3の画像 1 Kemove Snowfox 61 Key Switch Replacement: 手順 4、 3の画像 2 Kemove Snowfox 61 Key Switch Replacement: 手順 4、 3の画像 3
    この手順で使用する道具:
    Microfiber Cleaning Cloths
    $3.99
    購入する
    • Do not leave in sunlight or use a hairdryer because the heat might cause the plastic to warp or bend.
    • Take out the keycaps.
    • Ensure that the keycaps are separated and facing down.
    • Let the keycaps dry for 45 minutes.
    • If you cannot wait for 45 minutes, you may use a microfiber cloth and hand dry the keycaps. But be thorough in the cleaning process as there may be excess water inside the keycaps.
  5. Kemove Snowfox 61 Key Switch Replacement: 手順 5、 3の画像 1 Kemove Snowfox 61 Key Switch Replacement: 手順 5、 3の画像 2 Kemove Snowfox 61 Key Switch Replacement: 手順 5、 3の画像 3
    • Do not pull the key switch other than straight up.
    • Place the key switch puller above the key switch.
    • Push the tongs inward on both the white top and bottom ends.
    • Pull the key switch out.
    • Remove all key switches.
  6. Kemove Snowfox 61 Key Switch Replacement: 手順 6、 3の画像 1 Kemove Snowfox 61 Key Switch Replacement: 手順 6、 3の画像 2 Kemove Snowfox 61 Key Switch Replacement: 手順 6、 3の画像 3
    この手順で使用する道具:
    購入する
    • Do not squeeze or clean roughly as you may leak liquid into the board's interior.
    • Use a wet/ alcohol wipe and gently clean the surface board.
    • Use any tweezers or cotton swabs to clean tight corners of the board.
  7. Kemove Snowfox 61 Key Switch Replacement: 手順 7、 3の画像 1 Kemove Snowfox 61 Key Switch Replacement: 手順 7、 3の画像 2 Kemove Snowfox 61 Key Switch Replacement: 手順 7、 3の画像 3
    • Do not bend or hold by the golden pins.
    • Match the key switch with the keyholes.
    • Align the two golden pins with the two tiny holes located by the bottom.
    • Push down.
    • You will hear a loud clicking noise when the key switch has locked in place.
  8. Kemove Snowfox 61 Key Switch Replacement: 手順 8、 3の画像 1 Kemove Snowfox 61 Key Switch Replacement: 手順 8、 3の画像 2 Kemove Snowfox 61 Key Switch Replacement: 手順 8、 3の画像 3
    • Match the keycaps with the key switches.
    • Align the keycaps facing down and push straight.
    • Place all keycaps in their respective positions.
終わりに
Just like brand new!
作成者
2人の作成者と共同で作成されました。
Chandara Young
メンバー登録日: 10/05/21
157 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 11-80, Grodsky Fall 2021 CSU Los Angeles, Team 11-80, Grodsky Fall 2021人のメンバー
CSULA-GRODSKY-F21S11G80
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 30
今までの合計 829
