はじめに
Use this guide to remove and replace the vacuum motor in a Karcher Carpet Cleaner BRC3015C 2018.
必要な工具と部品
Pull the hose on the rear of the carpet cleaner straight down to disconnect it.
Pull the yellow and green ground wire connectors straight apart to disconnect the bottom cover's ground wire.
Use a flathead screwdriver to loosen the hose clamp securing the flexible hose to the vacuum motor.
Use a Phillips #2 screwdriver to remove the two screws securing the fan cover.
Use a Phillips #2 screwdriver to remove the screw securing the ground wire to the vacuum motor.
