はじめに
Use this guide to remove the pump cover in a Karcher Carpet Cleaner BRC3015C 2018.
必要な工具と部品
Pull the hose on the rear of the carpet cleaner straight down to disconnect it.
Pull the yellow and green ground wire connectors straight apart to disconnect the bottom cover's ground wire.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
