メインコンテンツにスキップ
K-Gro PowerPro Lawnmower Drive Cable Replacement Guide
必要な工具と部品
  1. K-Gro PowerPro Lawnmower Drive Cable Replacement Guide, Drive Engagement Cable: 手順 1、 2の画像 1 K-Gro PowerPro Lawnmower Drive Cable Replacement Guide, Drive Engagement Cable: 手順 1、 2の画像 2
    • Locate the throttle assembly on your mower on the right side of the push bar.
  2. K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: 手順 2、 3の画像 1 K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: 手順 2、 3の画像 2 K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: 手順 2、 3の画像 3
    • The throttle assembly is attached to the push bar with a 7/16" bolt and nut.
    • Using a 3/8" drive rachet wrench with a 7/16" socket and a 7/16" combination wrench, remove the nut.
    • Pull the plastic cable connection away from the framework.
  3. K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: 手順 3、 2の画像 1 K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: 手順 3、 2の画像 2
    • After disconnecting the plastic connector plate from the main body, you can see that the cable is hooked and looped around the orange handle.
    • Pull the cable towards the handle to allow the wire to become loose. This will give you enough room to remove the hook.
  4. K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: 手順 4、 3の画像 1 K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: 手順 4、 3の画像 2 K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: 手順 4、 3の画像 3
    • Following the cable down to the engine, you see that a zip tie holds the cable to the main handle.
    • Use a box cutter, sharp pocket knife, or cutting pliers to cut the zip tie.
    • Use gloves to prevent cutting yourself.
  5. K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: 手順 5、 2の画像 1 K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: 手順 5、 2の画像 2
    • Locate the plastic fitting hooked to the steel housing of the engine.
    • To the left of the fitting, you will see a steel sliding mechanism connected by a spring.
    • Squeeze the mechanism together to allow for slack in the cable wire.
    • You might need to use pliers or clamps in order to squeeze the plates together.
  6. K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: 手順 6、 3の画像 1 K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: 手順 6、 3の画像 2 K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: 手順 6、 3の画像 3
    • On close inspection of the plastic fitting, you can see that there are two "wings" that can be pinched together.
    • With the sliding mechanism squeezed and the wire slack, pinch the plastic wings together and push the fitting to the right out of the hole in the housing.
    • The loose wire can then be slid up through the groove in the steel.
  7. K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: 手順 7、 2の画像 1 K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: 手順 7、 2の画像 2
    • You can see that the only thing still holding the cable on is a hook attached to a spring loaded lever.
    • Remove the hook.
終わりに
ある他の人がこのガイドを完成しました。
作成者
8人の作成者と共同で作成されました。
Julio Acosta
メンバー登録日: 06/09/16
125 ポイント
1ガイドが承認済み
チーム
Texas Tech, Team 3-6, Rauch SU 2016 Texas Tech, Team 3-6, Rauch SU 2016人のメンバー
TTU-RAUCH-SU16S3G6
3 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 10
今までの合計 2,195
