はじめに
The speaker is located at the bottom of the the Justin Bieber Concert Microphone. The user will see there is a problem with the speaker if no sound is being produced. That is if the buttons are working and the batteries have charge. The speaker is the only component in the Justin Bieber Concert Microphone that is capable of producing sound.
  1. Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device. Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device.
    • Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device.
  2. Remove the 3 AAA batteries from the device.
    • Remove the 3 AAA batteries from the device.
  3. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Unscrew the other 4, #8 11.5 mm Phillips head screws to remove the entire back half of the device. Pull apart the device once screws are loose, splitting the device in half.
    • Unscrew the other 4, #8 11.5 mm Phillips head screws to remove the entire back half of the device.
    • Pull apart the device once screws are loose, splitting the device in half.
  5. Keeping all wires connected to their attachments, place the front half of the device face down.
    • Keeping all wires connected to their attachments, place the front half of the device face down.
  6. Remove the 2, #8 11.7 mm speaker guard screws with the Phillips Head screw driver. Remove the 2, #8 11.7 mm speaker guard screws with the Phillips Head screw driver.
    • Remove the 2, #8 11.7 mm speaker guard screws with the Phillips Head screw driver.
  7. Disconnect the speaker wires from the speaker and replace it with the new one
    • Disconnect the speaker wires from the speaker and replace it with the new one
    • Refer to this guide for help with soldering the wires back onto the speaker.
まとめ
Mike Seyman
メンバー登録日: 2014年10月19日
425 ポイント
4のガイドは作成済み
チーム
Baylor, Team 4-1, Williams Fall 2014 Baylor, Team 4-1, Williams Fall 2014人のメンバー
BU-WILLIAMS-F14S4G1
3 メンバー
4のガイドは作成済み
統計データを表示:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 83
