はじめに
When the machine is open, replacing the brewing unit is quite easy. Actually, you just need to take out the panel under the water tank, but it's a little easier if you open the machine completely using this guide.
必要な工具と部品
Position the machine with the water tank side facing you.
The panel covering the brew group is fixed at the top edge with two oval head screws.
Remove the two oval head screws and lift the panel out.
There it is: the brewing unit.
Start now with the replacement or revision of the brewing unit.
If you want to disassemble the brewing unit for cleaning and installing new seals, follow this or this guides.
There is one small difference with this brewing group: the drainage valve is fitted with a cover, but this is easy to remove. Unscrew the two Torx T8 screws.
Use these instructions to overhaul the drainage valve.
Work through the steps in reverse order to reassemble your device.
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
