はじめに
Like on almost all coffee machines the dispensing head van be clogged up by coffee grease, the Jura S models are no exception. Once blocked, no coffee will be dispensed by the nozzles. The coffee will run through the sides, or only one nozzle is open. You can try to clean the nozzles with a pipe cleaner, but this is not a good and long-term solution.
A revision and cleaning is not that difficult. For this purpose the machine has to be opened up.
必要な工具と部品
Lift out the coffee tray
Remove the lid sealing the coffee bean container
Remove all of the coffee beans you can possibly remove.
Pull the adjuster of the coffee bean grinder straight up
Remove the four T15 Torx screws
Remove the knob for the steam valve by simply pulling it off.
The front cover is secured with a Torx T15 screw. Remove it.
Turn the machine so that the back is facing you and push the coffee spout up as far as it will go.
Directly above the upper edge of the housing are two openings on the back of the coffee spout. In them you will see two detents. Carefully press the latches inwards, then you can remove the cover of the coffee spout.
Turn the coffee spout upside down. The inner coffee spout must be removed for cleaning.
This model still has a metal tube inserted for the tea water. First loosen the plastic lock, then carefully pull out the tube with wiggling movements.
The inner coffee inlet is still clipped in. Release the catch and lift it out.
Watch out for the magnets that act as a brake on the sliding plate. Do not lose them.
Follow the steps in reverse order to reassemble the machine.
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
